solid rocker spacers... |
crash914 |
Mar 28 2008, 07:42 PM
its a mystery to me Group: Members Posts: 1,826 Joined: 17-March 03 From: Marriottsville, MD Member No.: 434 Region Association: MidAtlantic Region |
A quick question.
With solid rocker spacers and washers. Which side should the washer be on? My guess is that they bracket the aluminum spacer to keep it from wearing down. But then the rockers are right up against the mounting posts....is this right? Thanks, |
toon1 |
Mar 29 2008, 09:39 AM
Senior Member Group: Members Posts: 1,849 Joined: 29-October 05 From: tracy,ca Member No.: 5,022 |
A quick question. With solid rocker spacers and washers. Which side should the washer be on? My guess is that they bracket the aluminum spacer to keep it from wearing down. But then the rockers are right up against the mounting posts....is this right? Thanks, The washers can go anywhere they are needed to make the alignment with the rocker tip and the valve correct. It is more important to have the alignment correct. |
crash914 |
Mar 29 2008, 09:41 AM
makes sense, not a lot of side load...thanks
Lo-Fi Version | Time is now: 31st May 2024 - 11:35 PM |
