Long Lugs or Short for 16x6, 16x7, FUCHS |
echocanyons |
Jan 15 2004, 07:40 PM
Advanced Member Group: Benefactors Posts: 2,094 Joined: 24-December 02 From: Bay Area, CA Member No.: 7 Region Association: Central California |
I need lugs for my wheels which are 911 fuchs sizes 16x6 and 16x7's
Is there any need for the long ones? Which look better? |
ChrisReale |
Jan 15 2004, 07:57 PM
Sleazy Group: Members Posts: 2,665 Joined: 20-January 03 From: San Francisco Member No.: 176 |
I could be wrong, but I think the only reason to use longer lugs is when you use spacers. That said, I use my stock lug bolts with my 15x7 wheels
Aaron Cox |
Jan 15 2004, 08:30 PM
what about fake fuchs....are they thicker?
campbellcj |
Jan 15 2004, 11:58 PM
I can't Re Member Group: Members Posts: 4,549 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California |
IME the standard lugs are fine; however I have seen at least two different depths of steel lug nuts. Both get adequate thread engagement but the shallower ones might be more likely to satisify any extra-anal tech inspectors you may run across (if you do autox or track events).
ArtechnikA |
Jan 16 2004, 06:56 AM
QUOTE(acox914 @ Jan 15 2004, 06:30 PM) what about fake fuchs....are they thicker? we're talking 5-lug Fuchs, yes ? mine are thicker. the stud is a teeny bit shorter than the end of the nut. i believe it's perfectly safe for the street, and if i were to AX on those wheels, i wouldn't be concerned about the lug engagement depth. i won't take them to DE events, tho ... (and not because of the stud length, because of the wheels ...) |
Joe Bob |
Jan 16 2004, 09:37 AM
I just got some one inch spacers and 72mm studs.
Lo-Fi Version | Time is now: 8th June 2024 - 10:19 AM |
