brake upgrade |
brake upgrade |
GTS |
Apr 2 2008, 07:28 AM
Member Group: Members Posts: 64 Joined: 7-October 04 From: South Austin,TX Member No.: 2,903 Region Association: None |
Hi All,
I can get the rear suspension of an 76 Carrera with the alloy trailing arms. Question can I make the brake set up work on my 74 914 to have the better brakes and the handbrake set up ?? Much appreciated. |
0396 |
Apr 2 2008, 07:31 AM
Advanced Member Group: Members Posts: 2,046 Joined: 13-October 03 From: L.A. Calif Member No.: 1,245 Region Association: Southern California |
Yes to all of your questions.. do a search
Joe Ricard |
Apr 2 2008, 10:35 AM
CUMONIWANNARACEU Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 |
WHat are you doing for the front.
Eric_Shea |
Apr 2 2008, 11:15 AM
PMB Performance Group: Admin Posts: 19,278 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
What Joe said?
I'm not a fan of the later (74+) assemblies as they don't have the proper bolt pattern. The early handbrake assemblies do. The later ones are a little wider to accomodate the larger bearings. It can be done but you'll have to elongate the holes. Calipers will bolt on but they'll need 5mm spacers under the ears and best to get longer bolts now. Make sure you address the entire system (fronts, rears, master cylinder) and I would caution against removing the factory proportioning valve. Good luck. |
GTS |
Apr 2 2008, 05:25 PM
Hi All and thank you for the comments.
Will do as advised. Front has the bigger brakes as well with air ducts etc. just with the back I was not satisfied. Will post pictures of the car when finished.Gonna be the wild thing.... |
Lo-Fi Version | Time is now: 31st May 2024 - 08:08 PM |
