How can I tell if these 96mm Arias Pistons are for 1.7/1.8 or 2.0 |
jcd914 |
Apr 13 2008, 12:19 AM
Advanced Member Group: Members Posts: 2,081 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
I am doing some spring cleaning (IMG:style_emoticons/default/sad.gif) and I am going to sell off some of the excess I have but before I can to that I need know what I have so I can decide if I should keep or sell. About a decade ago I bought a bunch of stuff for a Porsche shop having a yard sale. It was a pile of boxes that they did not want to put back away.
In one of these boxes was a set of new 96mm pistons with bored out 94mm mahle cylinders. I don't know if these are meant to go on a 1.7/1.8 bottom end or if they are for a 2.0 bottom end. I could install one on a partially assembled bottom end but I was hoping someone might know a way to measure and determine. These are Arias pistons with a dome on them. I don't think I have come across any other domed pistons for a 914 and I don't know anything about Arias. I have not pulled any of the pistons out of the cylinders yet but cylinder wall look nice and the pistons will move if I push. Any info would help me. Thanks Jim |
SLITS |
Apr 13 2008, 01:16 AM
If the pistons have a number on them I would call Arias.
PH 310 - 532 - 9737 | FAX 310 - 516 - 8203 | 13420 South Normandie Ave, Gardena, CA 90249 |
craig downs |
Apr 13 2008, 02:12 AM
Senior Member Group: Members Posts: 768 Joined: 25-November 05 From: mira loma ca. Member No.: 5,189 Region Association: Southern California |
All the cases from 1.7-2.0 are the same size for the cylinders. On the 1.7 where the
cylinder fits in the head is smaller than the 1.8 & 2.0. |
So.Cal.914 |
Apr 13 2008, 03:11 AM
Isn't the pin placement different?
SLITS |
Apr 13 2008, 09:09 AM
Gint |
Apr 13 2008, 10:07 AM
Mike Ginter Group: Admin Posts: 16,083 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
jcd914 |
Apr 13 2008, 02:03 PM
Thanks for the info everyone.
Yes the wrist pin location has to be different between pistons made to fit a 66mm stroke (1.7/1.8) bottom end and pistons made to fit a 71mm stroke (2.0) bottom end. So I guess I should have just asked if anyone had measurements for piston top to pin a 1.7/1.8 pistons and 2.0 pistons. I have not net joined Jake's forums so I won't know for a while what he has to say about the Arias piston fit. Thanks Jim |
craig downs |
Apr 14 2008, 12:37 AM
Oops I interpret the ? wrong when I read through it the 1st time.
I don't know the measurement for the pin height but the top of the bore for the pin on a 2.0 is right under the oil ring with a very small gap. The 1.7- 1.8 would have would have a larger gap. On a 2.0 piston from the top of the pin bore to the top of the piston is .922 Those pistons look heavy |
914werke |
Jul 20 2018, 10:21 AM
"I got blisters on me fingers" Group: Members Posts: 10,141 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Typically a visual inspection of the piston will tell you.
if the pin position is much lower than the ring lands it is for the 66mm stroke crank if the pin position is just below the lower ring land it is 71mm |
SirAndy |
Jul 20 2018, 12:08 PM
Resident German Group: Admin Posts: 41,679 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Typically a visual inspection of the piston will tell you. if the pin position is much lower than the ring lands it is for the 66mm stroke crank if the pin position is just below the lower ring land it is 71mm This thread is 10 years old ... (IMG:style_emoticons/default/huh.gif) |
73-914 |
Jul 20 2018, 12:17 PM
Senior Member Group: Members Posts: 579 Joined: 24-April 10 From: Albany UpstateNY Member No.: 11,651 Region Association: None |
LOL
ClayPerrine |
Jul 20 2018, 02:00 PM
Life's been good to me so far..... Group: Admin Posts: 15,521 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Robnxious |
Jul 20 2018, 02:09 PM
RobnxiousOne Group: Members Posts: 184 Joined: 26-October 06 From: Sacramento Member No.: 7,097 Region Association: Northern California |
Al Meredith |
Jul 20 2018, 03:32 PM
Senior Member Group: Members Posts: 960 Joined: 4-November 04 From: Atlanta, ga Member No.: 3,061 |
real simple! take a standard 1.7 piston and insert a rist pin in 1/2 way, then take the piston in question and insert the other end of the pin in it and if the top of both pistons are the same , it is a 1.7/1.8 . If the piston in question is shouter than 1.7 piston then it is a 2.0.
Lo-Fi Version | Time is now: 10th June 2024 - 09:19 AM |
