How Do I remove the Window and Frame |
7TPorsh |
Apr 21 2008, 12:07 PM
7T Porsh Group: Members Posts: 2,691 Joined: 27-March 06 From: Glendale Ca Member No.: 5,782 Region Association: Southern California |
Well, putting the car back together after paint...go to start on the doors and realize the replacement door I bought has a clear window not a tinted one.
So I need to swap out the whole assembly of with the stainless front frame and window. I can see two bolts, one at the bottom and one burried at the corner where the vent window is. is there a process? |
McMark |
Apr 21 2008, 01:35 PM
Are you talking about replacing just the triangle corner window? Or the roll up window as well?
7TPorsh |
Apr 21 2008, 03:52 PM
The rollup. The vent window and seal is out, door panel out. Want to remove the long, forward frame piece and window. It is a 1970 so it looks like the window has a metal piece attached to it.
r_towle |
Apr 21 2008, 06:02 PM
Custom Member Group: Members Posts: 24,588 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
take out the two screws on the horizontal channel that the window roller goes in...its on the bottom of the glass.
It should come out the top. You may have to remove the inner fuzzy strip. Rich |
Lo-Fi Version | Time is now: 8th June 2024 - 04:11 PM |
