CV joint bolts, Will VW bus bolts work? |
zonedoubt |
Apr 22 2008, 03:23 PM
Canadian Member Group: Members Posts: 668 Joined: 14-May 03 From: Vancouver, BC Member No.: 696 Region Association: Canada |
I was going to pick up some of these when I order a CV joint removal tool:
http://www.cip1.ca/ProductDetails.asp?Prod...2D501%2D229%2DD They're 8x48mm with a hex socket instead of 12 point. Is that the right size to fit the 914? |
ericread |
Apr 22 2008, 03:39 PM
The Viper Blue 914 Group: Members Posts: 2,177 Joined: 7-December 07 From: Irvine, CA (The OC) Member No.: 8,432 Region Association: Southern California |
Dude;
Take a look at Dr. Evil's CV bolts. They're not expensive and they are drilled and supplied with wire to ensure they do not back out. He's in the "Member Vendor" forum (no affiliation). |
RoninEclipse2G |
Apr 22 2008, 03:42 PM
Suby Geek Group: Members Posts: 232 Joined: 28-April 07 From: Parker, Colorado Member No.: 7,701 Region Association: Rocky Mountains |
the size is the same, but get the 12 point. hex heads strip out way too easy.
VW part # is an 893-407-237 and they run about $2 a piece from VW you can get the triple square sockets for about $8 at NAPA best option is to get Dr. Evil's super CV bolt kit though |
Lo-Fi Version | Time is now: 7th June 2024 - 11:41 PM |
