Posts in this area are restricted to the following format. If you have a general question, please post it in the Garage.
1. All new threads MUST be titled with a part number only. (i.e. 901.351.801.17)
2. Thread description should be an english description of the part. (i.e. Brake Dust Shields)
3. Replies to the thread are only restricted by pertinence. Some examples are original finish of the part (painted, cad plated, etc), common failures (cracking at the mount points), repair information or tips, pictures (stock or custom), upgrades, etc.
If you have any questions regarding the rules of this forum, please PM McMark.
McMark |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,180 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None ![]() |
This piece hold the rear bearing in place inside the trailing arms. They are identical for either side. They appear to be originally yellow zinc plated, according to the set I recently tore down. The plate is held in place by four yellow zinc plated 8mm x 1.25 x 15mm bolts with yellow zinc split lock washers.
Bolts - 900.075.078.02 Washers - 900.027.015.02 The PET illustration shows this part as being round, but as the images show the actual shape. I haven't seen a round one, including the original 914-6 ones I've worked on. Attached thumbnail(s) ![]() ![]() Attached image(s) ![]() |
Lo-Fi Version | Time is now: 13th July 2025 - 04:55 PM |
