Ran out of Gas sh@# f%$%, Now it won't start...... |
ldino21 |
Jan 20 2004, 12:17 PM
Member Group: Members Posts: 62 Joined: 18-February 03 From: Fresno, CA Member No.: 316 |
Driving the car home last night with the gas gauge reading 1/2 full my car all of a sudden sputtered and stalled like it ran out of gas!! I went to the gas station got a gallon of gas and it still would not start.
Is there anything special I should know, to try to get this to start? could I have blown a fuel injector?? Is maybe a gallon not enough in the tank and I need to add a couple more?? Any suggestions would help!! By the way its a 1973 1.7 with D-Jet injection |
Mueller |
Jan 20 2004, 12:22 PM
You might have to trick the fuel pump into running while the car is off in order to "fill" up the fuel rails....not too sure, just a wild guess
ArtechnikA |
Jan 20 2004, 12:27 PM
rich herzog Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None |
QUOTE(ldino21 @ Jan 20 2004, 10:17 AM) Driving the car home last night with the gas gauge reading 1/2 full my car all of a sudden sputtered and stalled like it ran out of gas!! "like" it ran out of gas? did it or didn't it ? do you have a reason not to trust the gauge ? did you stick the tank for a more reliable indicatition ? did you look inside ? if there's axtually half a tank of gas, adding another gallon won't help your problem ... if you "suddenly" lost half a tank of gas, look for the source of the big leak, and fix that. if it actually has gas, check for the other likely suspects: fuel pressure (do you hear the pump running?) and ignition (more likely). if you actually -did- run out of gas and your gauge is defective (although - usually the light will still work unless you have a stuck float...) it may take several key on/key off cycles to purge the air from the fuel loop and develop fuel pressure. you should hear the fuel pump run a second or two when you cycle the key. |
Joe Bob |
Jan 20 2004, 12:28 PM
Retired admin, banned a few times Group: Members Posts: 17,427 Joined: 24-December 02 From: Boulder CO Member No.: 5 Region Association: None |
Ether/quick start....if that doesn't do it....you have other issues.
SirAndy |
Jan 20 2004, 12:51 PM
Resident German Group: Admin Posts: 41,688 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
(IMG:style_emoticons/default/agree.gif) all the above.
also, IF you ran out of gas, your fuel filter is most likely plugged with crap now that had been sitting on the bottom of your tank. you needa change the filter first. again, that's IF you actually ran out of gas. Andy |
Seaside6 |
Jan 20 2004, 12:56 PM
Member Group: Members Posts: 51 Joined: 29-December 03 From: Seaside, CA Member No.: 1,475 Region Association: Northern California |
I thought mine had run out of gas and I added 2 gallons. I cranked and I cranked trying get it started. After replacing the fuel filter and eventually having it towed my mechanic found that the rotor was shot!
Seaside6 |
ldino21 |
Jan 20 2004, 01:31 PM
After adding the gas, the motor cranked and cranked and just wouldn't start, a couple of times it sounded like it was starting but wouldn't. I cranked so much that the battery went low, had to start jumping it.
This happened once before when the gauge was at half full the car wouldn't crank over, me in my infinite wisdom thought it was because one of the electical wires to the fuel pump was frayed so I replaced the whole fuel system electrical. It still didn't crank so I took it to the shop, they ended up replacing the distributor, a couple bad injectors and said that it was out of GAS!! $500 bucks later it was running. I am hoping not to have to do that again!!! |
TheCabinetmaker |
Jan 20 2004, 01:39 PM
I drive my car everyday Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Indio, Did you hear the fuel pump? Could you smell gas? Did you check for spark? Are you fuel injected?
You can fix it. We can help. |
ArtechnikA |
Jan 20 2004, 01:40 PM
QUOTE(ldino21 @ Jan 20 2004, 11:31 AM) I am hoping not to have to do that again!!! you gotta let us help you by providing more information. how much gas is in the tank, REALLY ? when you turn the key to the 'on' position, do you hear the fuel pump run for a moment ? (if no, find out why your fuel pump is not running. CHECK THE FUSES - all of them) pull a spark plug. if there is fuel pressure but no spark the plug will probably be wet with gas; find and fix the ignition problem. all further speculation is pointless until we know what kind of problem you're dealing with. it's probably something simple but right now, it could still be anything ... |
ldino21 |
Jan 20 2004, 01:49 PM
Yes the fuel pump runs every time, no problem. I will stick something down the tank, when I get home tonight to see the fuel level. I have not checked for spark which I will do tonight!!!
mike_the_man |
Jan 20 2004, 01:56 PM
I like stuff! Group: Members Posts: 1,338 Joined: 11-June 03 From: Regina, Saskatchewan, Canada Member No.: 809 |
The same thing used to happen to my Volvo all the time. It was something really simple. Sometimes the fuses wouldn't make good contact (it had the same crappy european ones as teeners). If I just spun the fuses in their holders it would start. Something simple to check, although not likely your problem.
mightyohm |
Jan 20 2004, 06:55 PM
Advanced Member Group: Benefactors Posts: 2,277 Joined: 16-January 03 From: Seattle, WA Member No.: 162 Region Association: Pacific Northwest |
Open the fuel cap and look inside with a flashlight. You can totally see in there to check if there is gas.
736conver |
Jan 20 2004, 07:00 PM
Advanced Member Group: Members Posts: 2,117 Joined: 25-May 03 From: SE Wisconsin Member No.: 736 Region Association: None |
It does sound like a spark issue.
Bleyseng |
Jan 20 2004, 07:01 PM
Aircooled Baby! Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
Don't use a match to look down into the gas tank (IMG:style_emoticons/default/laugh.gif)
redshift |
Jan 20 2004, 07:21 PM
Bless the Hell out of you! Group: Members Posts: 10,926 Joined: 29-June 03 Member No.: 869 |
The early Haynes says to use a torch.
M |
ejm |
Jan 20 2004, 08:11 PM
I can see the light at the end of the tunnel Group: Members Posts: 2,695 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None |
QUOTE(redshift @ Jan 20 2004, 05:21 PM) The early Haynes says to use a torch. Yes..the rare first edition.... Most copies were incinerated while following directions (IMG:style_emoticons/default/laugh.gif) |
SirAndy |
Jan 20 2004, 08:17 PM
QUOTE(ejm @ Jan 20 2004, 06:11 PM) QUOTE(redshift @ Jan 20 2004, 05:21 PM) The early Haynes says to use a torch. Yes..the rare first edition.... Most copies were incinerated while following directions (IMG:style_emoticons/default/laugh.gif) mine still does (IMG:style_emoticons/default/smile.gif) but it also sais: "Any reference to a "torch" appearing in this manual should always be taken to mean a hand-held, battery-operated electrical light or flashlight. it DOES NOT mean a welding or propane torch or blowtorch." (IMG:style_emoticons/default/laugh.gif) Andy |
Gint |
Jan 20 2004, 10:47 PM
Mike Ginter Group: Admin Posts: 16,083 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
QUOTE but it also sais: "Any reference to a "torch" appearing in this manual should always be taken to mean a hand-held, battery-operated electrical light or flashlight. it DOES NOT mean a welding or propane torch or blowtorch." Must be the "'Murican Edition". |
Bruce Allert |
Jan 20 2004, 10:49 PM
Hellions asleep Group: Members Posts: 3,289 Joined: 19-March 03 From: Eagle Creek, Orygun Member No.: 441 Region Association: Pacific Northwest |
I used a match to see if my battery was low! (IMG:style_emoticons/default/ohmy.gif) That was in my hippy daze. My eyebrows are back now (IMG:style_emoticons/default/wacko.gif)
........b |
Curvie Roadlover |
Jan 21 2004, 04:21 AM
Two trunks are better than one! Group: Members Posts: 2,025 Joined: 29-December 02 From: Southeast Michigan Member No.: 42 |
QUOTE(mike_the_man @ Jan 20 2004, 11:56 AM) The same thing used to happen to my Volvo all the time. It was something really simple. Sometimes the fuses wouldn't make good contact (it had the same crappy european ones as teeners). If I just spun the fuses in their holders it would start. Something simple to check, although not likely your problem. (IMG:style_emoticons/default/agree.gif) This happened to me. The car was running fine then just quit. After freaking out a little (this happened on the first day of ownership and I still had to drive the car 3000 miles home that week) I rolled the fuses on the relay board for the fuel pump in their holders per Brads' suggestion (Thanks, B!!) it started right up and I haven't had a problem since. |
Lo-Fi Version | Time is now: 16th June 2024 - 06:28 PM |
