can someone please explain to me, and/or console me on my loss |
mrhurtalot |
May 7 2008, 09:15 PM
VRRRRRRROOOOOOOOOM! Group: Members Posts: 323 Joined: 5-October 06 From: Yukon, Oklahoma Member No.: 6,996 |
(EDIT) heres a link to the post with pics.. http://www.914world.com/bbs2/index.php?sho...3727&st=25#
my teener was out of commission since about october until two weeks ago, i finally got the cv fixed and reshaped the shift rod and several other little things. man, it was awesome, for two weeks the weather here was perfect, i had the top off, just cruising about. looking like a BAMF. (IMG:style_emoticons/default/driving-girl.gif) but today, i pull out of my garage, drive about 3 blocks down my street, stop at the stop sign. I start to go, when suddenly BAM! the exact same thing happens. the cv bolts shear off. car stops. and i go off. so, ive probably got a bent cv joint. and a bent shift rod again. can someone please explain. ive only got a 2.0. nothing fancy. this shouldnt be happening. unless its an undocumented feature of some sort. (IMG:style_emoticons/default/WTF.gif) |
SirAndy |
May 7 2008, 09:21 PM
Resident German Group: Admin Posts: 41,679 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
can someone please explain. ive only got a 2.0. nothing fancy. this shouldnt be happening. unless its an undocumented feature of some sort. do you have the two pins that are supposed to lock the CVs and stubs together? if you only have the 4 bolts but not the two pins, you're asking for trouble ... (IMG:style_emoticons/default/idea.gif) Andy |
mrhurtalot |
May 7 2008, 09:30 PM
to my knowledge, yes, there are the spiral pins. i had that thought earlier, but pushing a car uphill for like 3 blocks generally makes one very tired and reluctant to slide under a car and check.
but i see no reason as to why they would suddenly be gone. |
SirAndy |
May 7 2008, 09:33 PM
to my knowledge, yes, there are the spiral pins. i had that thought earlier, but pushing a car uphill for like 3 blocks generally makes one very tired and reluctant to slide under a car and check. but i see no reason as to why they would suddenly be gone. with the pins in place, they *only* way you can shear off the bolts is if all the bolts came lose. there's no other way (well, maybe if you're pushing 1000 HP) ... did you use NEW schnorr washers for the bolts? did you use the correct torque? did you make sure the thread was clean and not gunked up before you torqued down the bolts? new gaskets? (IMG:style_emoticons/default/idea.gif) Andy PS: (IMG:style_emoticons/default/thisthreadisworthlesswithoutpics.gif) |
r_towle |
May 7 2008, 09:38 PM
Custom Member Group: Members Posts: 24,591 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Gaskets...
I had simliar issues till I actually looked at the book and found a gasket in there....if you dont have it the bolts will feel tight, the the CV joint is never crushing the gasket so the bolts get loose. Pull out the bolts, drill holes in them like Dr Evil does (or buy his) and use wire through the heads, new washers and new gaskets. Rich |
mrhurtalot |
May 7 2008, 10:07 PM
will get pics tomorrow.
new gasket was in place. new bolts. yes washers. again. let me emphasize that the car has been driven for less than two weeks after all repairs were complete. i seriously doubt that the bolts just came loose. bleeh thanks for the fast responses guys. ive got a fun day lined up tomorrow. (IMG:style_emoticons/default/smile.gif) |
PeeGreen 914 |
May 7 2008, 10:13 PM
Just when you think you're done...wait, there is more..lol Group: Members Posts: 10,219 Joined: 21-September 06 From: Seattle, WA... actually Everett Member No.: 6,884 Region Association: Pacific Northwest |
You still didn't say if you have the studs in there or not. (IMG:style_emoticons/default/confused24.gif)
r_towle |
May 7 2008, 10:15 PM
Gint |
May 7 2008, 10:16 PM
Mike Ginter Group: Admin Posts: 16,083 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
You did say...
the cv bolts shear off. car stops. Did they shear off, fall off, what? Have a look at it and get some pics. ive got a fun day lined up tomorrow. (IMG:style_emoticons/default/smile.gif) Look at the bright side. It beats swapping out a transaxle for the second time in a week. |
SGB |
May 7 2008, 10:29 PM
just visiting Group: Members Posts: 4,086 Joined: 8-March 03 From: Huntsville, AL Member No.: 404 Region Association: South East States |
I don't have spiral pins. I have little protuding cylindrical stubs, Maybe 8mm dia by 4mm tall.
I think something is wrong there, and has been from the start. Those pins -er, I mean stubs- stick in pretty far... |
PeeGreen 914 |
May 7 2008, 10:36 PM
I don't have spiral pins. I have little protuding cylindrical stubs, Maybe 8mm dia by 4mm tall. I think something is wrong there, and has been from the start. Those pins -er, I mean stubs- stick in pretty far... (IMG:style_emoticons/default/agree.gif) |
mrhurtalot |
May 8 2008, 12:12 AM
by spiral pins, i meant the stubs. just to clarificate that.
McMark |
May 8 2008, 12:15 AM
They sheared off???? (IMG:style_emoticons/default/ohmy.gif)
If the pins are in place, and the bolts sheared off (not unscrewed) then perhaps they were over-tightened to the point where they were just waiting to break. If the bolts did unscrew then use Dr. Evil's drilled bolts. And always clean the grease out of the bolt holes and threads with Q-Tips and brake cleaner. The less grease in the threads, the less chance it will unscrew itself. |
jd74914 |
May 8 2008, 12:46 AM
Its alive Group: Members Posts: 4,782 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States |
I would think that the threads would strip or be pulled off before you could force a bolt to shear.
If you had the pins they must have been loose? |
akellym |
May 8 2008, 06:20 AM
Eyes Of The Deep Battle Group: Members Posts: 597 Joined: 25-July 04 From: Annandale, MN Member No.: 2,395 Region Association: Northstar Region |
Don’t use gaskets!! They will compress over time. Just use silicon to seal it. Loctite will keep your bolts from coming loose.
SGB |
May 8 2008, 07:05 AM
Evil safety wired bolts are cheap insurance.
r_towle |
May 8 2008, 07:38 AM
ChrisFoley |
May 8 2008, 08:08 AM
I am Tangerine Racing Group: Members Posts: 7,934 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
Don’t use gaskets!! They will compress over time. Just use silicon to seal it. Loctite will keep your bolts from coming loose. I respectfully disagree. If no gasket is used the CV joint does not fit correctly Rich I disagree with both of you. (IMG:style_emoticons/default/happy11.gif) The gasket does not affect the alignment/fit of the cv to the flange. What it does is prevent grease from slinging all over the place. A bead of silicone will not stay put for long. The centrifugal force will make it come off. At least on a track car thats what happens. |
Mark Henry |
May 8 2008, 08:15 AM
The spiral pins are fine, Porsche use both spiral and solid over the years.
ericread |
May 8 2008, 09:41 AM
The Viper Blue 914 Group: Members Posts: 2,177 Joined: 7-December 07 From: Irvine, CA (The OC) Member No.: 8,432 Region Association: Southern California |
I would think that the threads would strip or be pulled off before you could force a bolt to shear. If you had the pins they must have been loose? (IMG:style_emoticons/default/agree.gif) That's some amazing torque that would cause four bolts to shear off! I can't wait to the the pictures... |
Lo-Fi Version | Time is now: 9th June 2024 - 05:57 PM |
