Allan |
Teenerless Weenie ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California ![]() |
For a /6 with carbs.
8mm? Magnecore? Other? |
smontanaro |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,190 Joined: 3-June 05 From: Evanston, IL Member No.: 4,197 Region Association: Upper MidWest ![]() |
Lots of stuff to read about this topic on the Bird Board's 911 forum: http://forums.pelicanparts.com/search.php?searchid=1639080
Skip |
J P Stein |
Irrelevant old fart ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,797 Joined: 30-December 02 From: Vancouver, WA Member No.: 45 Region Association: None ![]() |
For a /6 with carbs. 8mm? Magnecore? Other? It's a system. I use MSD 6al, MSD High Vibration coil, 8.5mm Magnecore wires & NGK plugs gapped to .045-.050 (depends on how I feel that day). (IMG:style_emoticons/default/biggrin.gif) |
Allan |
I'm running a Mallory 6AL, MSD Blaster II coil, and Pertronix.
MSD box went to electrical heaven. (IMG:style_emoticons/default/sad.gif) |
J P Stein |
I'm running a Mallory 6AL, MSD Blaster II coil, and Pertronix. MSD box went to electrical heaven. (IMG:style_emoticons/default/sad.gif) I use the Pertronixs also. Been using the MSD for 8-9 years without a problem, but am not attached to it. Most all of the multi-spark units will do the trick as long as they can maintain the voltage that the high voltage coils can produce. IIRC, John Rogers measured the voltage of the MSD unit at 18K during the multi-spark phase and 36K above that to 7kish and it didn't "run out of gas" electrically speaking. |
Gint |
Mike Ginter ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,083 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains ![]() ![]() |
Magnecore on mine...
Lo-Fi Version | Time is now: 10th June 2024 - 08:59 PM |
