Prep car for Porsche Parade |
watsonrx13 |
May 15 2008, 04:07 PM
Advanced Member Group: Members Posts: 2,734 Joined: 18-February 03 From: Plant City, FL Member No.: 312 Region Association: South East States |
Well, I'm getting close to finishing my second project car and I'm trying to get it ready for a trip from Tampa, FL to Charlotte, NC for Porsche Parade (arrive June 28th). I've owned this car for over 2 years, but I've never driven it. Currently it's mostly put back together, but I still have a lot to do. I need to install the front and rear calipers, clean the engine and tranny and reinstall. The engine is a stock 2.0l FI. Anyway, I put together a list of the things I need to do and/or parts I need to purchase and the vendor. If anyone has other suggestions, please add your comments...
alternator belt - AA push rod tube seals - VW shop spark plugs - VW shop - Bosch W7CC spark plug wires - CB Performance oil - on hand oil filter - on hand points - VW shop condensor - VW shop front motor mounts - ???? rear motor mounts - ???? tranny speedo gear - on hand throttle cable - AA clutch cable - AA speedo cable - AA (4) flex brake lines - AA brake fluid - on hand repack CV joints - me CV schnorr washers - McMaster-Carr rear suspension adjustment schnorr washers - McMaster-Carr rubber fuel lines - AA plastic fuel lines from FI fuel pump - AA vacuum hoses - AA fuel filter - Autozone FI rubber elbows - AA muffler copper gaskets drain tranny oil and replace - me bleed brakes - me adjust front suspension height - me all gear shift bushings - parts on hand rear sway bar bushings - parts on hand time engine - me adjust valves - me clean injectors - can I soak them in carb cleaner? -- Rob |
gasman |
May 15 2008, 04:53 PM
Member Group: Members Posts: 107 Joined: 21-January 08 From: Mooresville, nc Member No.: 8,602 Region Association: South East States |
Well, I'm getting close to finishing my second project car and I'm trying to get it ready for a trip from Tampa, FL to Charlotte, NC for Porsche Parade (arrive June 28th). I've owned this car for over 2 years, but I've never driven it. Currently it's mostly put back together, but I still have a lot to do. I need to install the front and rear calipers, clean the engine and tranny and reinstall. The engine is a stock 2.0l FI. Anyway, I put together a list of the things I need to do and/or parts I need to purchase and the vendor. If anyone has other suggestions, please add your comments... alternator belt - AA push rod tube seals - VW shop spark plugs - VW shop - Bosch W7CC spark plug wires - CB Performance oil - on hand oil filter - on hand points - VW shop condensor - VW shop front motor mounts - ???? rear motor mounts - ???? tranny speedo gear - on hand throttle cable - AA clutch cable - AA speedo cable - AA (4) flex brake lines - AA brake fluid - on hand repack CV joints - me CV schnorr washers - McMaster-Carr rear suspension adjustment schnorr washers - McMaster-Carr rubber fuel lines - AA plastic fuel lines from FI fuel pump - AA vacuum hoses - AA fuel filter - Autozone FI rubber elbows - AA muffler copper gaskets drain tranny oil and replace - me bleed brakes - me adjust front suspension height - me all gear shift bushings - parts on hand rear sway bar bushings - parts on hand time engine - me adjust valves - me clean injectors - can I soak them in carb cleaner? -- Rob I'll see you there................... |
type47 |
May 15 2008, 05:17 PM
send the injectors out to be cleaned or whatever they do. there is a place that does them for $12 each
mightyohm |
May 15 2008, 05:28 PM
Advanced Member Group: Benefactors Posts: 2,277 Joined: 16-January 03 From: Seattle, WA Member No.: 162 Region Association: Pacific Northwest |
www.pelicanparts.com
Lo-Fi Version | Time is now: 1st June 2024 - 06:09 PM |
