Evaluating turn signal flasher relay, have turnsignal problems |
retrofit |
Jun 5 2008, 06:42 PM
Member Group: Members Posts: 176 Joined: 17-April 04 From: Turlock,Ca Member No.: 1,943 |
(IMG:style_emoticons/default/WTF.gif) How can I test the turn signal flasher relay to make sure it is ok? My Turn sigs don't light up or flash. Check the relay? How often are turn sig probs due to relay failure? If mine is fried are these available at flaps or go to Pelican?
TIA Allen |
jetboy |
Jun 5 2008, 11:14 PM
914 Uber Noob Group: Members Posts: 205 Joined: 16-September 05 From: Riverside, CA Member No.: 4,810 Region Association: Southern California |
Did you check the fuses first? I had a problem with mine (i would even see the rpm guage jumping around when they were turned on) but then i noticed my fuse had dislodged itselft. 1st reply so i guess i get to state the obvious.
Snafu |
Jun 7 2008, 02:55 PM
Member Group: Members Posts: 70 Joined: 29-April 07 From: Beaumont, Texas Member No.: 7,704 Region Association: Southwest Region |
retrofit |
Jun 7 2008, 06:10 PM
Thanks Snafu. I'm going to follow that thread step-by-step. Let's see what happens. Allen/retrofit/mouthfulofspiders |
Snafu |
Jun 7 2008, 09:35 PM
Hope it helps...
My switch was fried. My fault.. I crossed the wires when reconnecting the turn signals. |
Lo-Fi Version | Time is now: 4th June 2024 - 01:47 PM |
