9mm fuel line - does it exist?, Or what should I use? |
JeffBowlsby |
Jun 30 2008, 03:00 PM
914 Wiring Harnesses Group: Members Posts: 8,537 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Unde the gas tank on my 74 cars, are 10mm fittings on the tank with a 10mm fuel line through the center tunnel. I think I should use 9mm fuel line but cannot find any source. What should I use and where to get it?
ConeDodger |
Jun 30 2008, 03:02 PM
Apex killer! Group: Members Posts: 23,618 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
Unde the gas tank on my 74 cars, are 10mm fittings on the tank with a 10mm fuel line through the center tunnel. I think I should use 9mm fuel line but cannot find any source. What should I use and where to get it? I couldn't find it. I used a US spec size... |
Cap'n Krusty |
Jun 30 2008, 03:03 PM
How much you want? I have a meter or so, and can get more. I'm sure HPH stocks it, as well. The Cap'n
JeffBowlsby |
Jun 30 2008, 03:11 PM
I need a meter, enough for 2 cars under the tank. Can you send it to me and how would you like payment?
Thanks John! |
roadster fan |
Jun 30 2008, 03:27 PM
Project Frankenstein !!!!!!!! Group: Members Posts: 1,009 Joined: 24-November 05 From: Aptos, CA Member No.: 5,184 Region Association: Northern California |
I used 3/8".......let the flames begin. Works good and I can find it at any FLAPS.
Jim I did use 7mm for the smaller line if that counts (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 13th June 2024 - 06:34 AM |
