fuel leak, filter? |
robby750 |
Aug 28 2008, 11:43 AM
Senior Member Group: Members Posts: 646 Joined: 6-April 03 From: Lexington, Ky Member No.: 521 Region Association: South East States |
I kept smelling gasoline in the cabin so I did some checking and found the filter was moist and has a gas odor. It is under the tank and I can get to it from the front pump access cover. The lines and filter were replaced 2 years ago and the lines look good. My question is, is this very common? It is a genuine Porsche replacement filter.
Attached image(s) |
TravisNeff |
Aug 28 2008, 11:47 AM
It could be the fittings on the tank that are weeping.
robby750 |
Aug 28 2008, 11:49 AM
rjames |
Aug 28 2008, 01:55 PM
I'm made of metal Group: Members Posts: 3,936 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
It could be the fittings on the tank that are weeping. I pulled the tank up and checked. Everything was dry but the filter. Sounds like you answered your own question. (IMG:style_emoticons/default/smile.gif) They are cheap, replace it and see if it fixes your issue. |
Cap'n Krusty |
Aug 28 2008, 02:54 PM
Not a particularly uncommon problem. We use metal filters on the earlier cars, but they don't fit yours. The Cap'n
r_towle |
Aug 28 2008, 03:44 PM
Custom Member Group: Members Posts: 24,579 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
I had a friend William Harris who blew out a brand new one..
Apparently the latest batch is junk and they do leak. I was also told go with a BMW filter, same fittings on each end... Rich |
Lo-Fi Version | Time is now: 23rd May 2024 - 07:50 AM |
