Please help! Another winking/oscilating headlight question, Switch on and sometimes they will start "the dance". |
BRAVE_HELIOS |
Sep 18 2008, 10:52 PM
"Knowledge speaks, wisdom listens" Group: Members Posts: 295 Joined: 25-September 06 From: The Land Of ID! Member No.: 6,920 Region Association: Pacific Northwest |
(IMG:style_emoticons/default/WTF.gif) So sometimes when I switch the headlights on , they will begin to oscilate, wink, blink... as one comes up the other goes down and they will continue to do this until I switch them off (they both go to the off/down position). Then if I switch them on again, they will operate normally. I've swapped relays by the headlights; but made no difference.
Any ideas or thoughts? (IMG:style_emoticons/default/type.gif) |
smooth_eddy |
Sep 19 2008, 01:18 AM
Senior Member Group: Members Posts: 535 Joined: 13-November 04 From: Seattle Member No.: 3,102 |
Check the relay's first. I had the same problem. I just cleaned the relay's and sockets with contact cleaner and they were fine after that. If that does not work, try chasing bad grounds.
Good luck. Eddy |
URY914 |
Sep 19 2008, 07:29 AM
I built the lightest 914 in the history of mankind. Group: Members Posts: 121,038 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
Mine did this for a few days. Kids loved it. Made for tough driving at night.
Also rotate your fuses in the fuse holder. Sometimes crap can collect on the connections an cause resistance. Mine corrected themselves. |
SirAndy |
Sep 19 2008, 12:00 PM
Resident German Group: Admin Posts: 41,677 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Check the relay's first. I had the same problem. I just cleaned the relay's and sockets with contact cleaner and they were fine after that. If that does not work, try chasing bad grounds. (IMG:style_emoticons/default/agree.gif) |
Lo-Fi Version | Time is now: 8th June 2024 - 04:44 PM |
