Suspension Weirdness ..., spungy - sloppy - wobbly |
SirAndy |
Feb 6 2004, 03:13 AM
Resident German Group: Admin Posts: 41,679 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
ok, sooooo, on my way back from Jeffs tonight,
there is this off-ramp (45mph limit) with all new asphalt and nice and all and i decided to push it a bit. i was going through at a bit over 100mph and the car was sticking well and all, no under- or oversteer, no sliding, BUT the front suspension felt somehow wooble-y. i sort of had to do this (IMG:style_emoticons/default/driving.gif) (not that extreme mind you) as the car was slightly rocking. weirdly enough it didn't feel unsafe as the tires were sticking. what is that? (IMG:style_emoticons/default/confused24.gif) could it be the sidewalls flexing? i'm running 225/50x15 on 7" rims. shocks toast? (did the push down test which they passed). comments are apprechiated, Andy |
ChrisFoley |
Feb 6 2004, 06:20 AM
I am Tangerine Racing Group: Members Posts: 7,934 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
Make sure the nut (threaded collar) that holds the shock in the strut is tight. Check all the nuts & bolts holding the suspension to make sure something hasn't come loose.
JWest |
Feb 6 2004, 07:36 AM
Senior Member Group: Members Posts: 1,662 Joined: 6-January 03 From: Fort Worth, TX Member No.: 97 Region Association: None |
Push down test only works on '72 Buicks. You can have completely toasted shocks and pass the push down test on Porsches (my experience anyway).
Jeroen |
Feb 6 2004, 08:33 AM
914 Guru Group: Members Posts: 7,887 Joined: 24-December 02 From: The Netherlands Member No.: 3 Region Association: Europe |
Hey Andy,
Can you try to describe it a little better? Bumpsteer maybe? How are your susp.bushings? cheers, Jeroen |
rhodyguy |
Feb 6 2004, 08:44 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,093 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
perhaps you simply reached the limits of your setup. maybe 90 mph is a prudent rate of speed in that section.
kevin |
r_towle |
Feb 6 2004, 08:45 AM
Custom Member Group: Members Posts: 24,591 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Hey J...
Could be the adjuster on the rear of the torsion bar is a little loose fitting (IMG:style_emoticons/default/wink.gif) (IMG:style_emoticons/default/wink.gif) |
Don Wohlfarth |
Feb 6 2004, 09:36 AM
Member Group: Members Posts: 104 Joined: 8-January 03 From: Fairfax, VA Member No.: 117 |
Andy, don't see how it could be your tires. 225's on 7" rim should give you a pretty straight sidewall and you'r got 50 series tires.
Make sure all the suspension bolts are tight. Check for worn rubber bushings. Could be that Kevin's right, taking a 45mph ramp at 100+ could make a GT3 feel a little strange. |
Jeroen |
Feb 6 2004, 09:53 AM
QUOTE(r_towle @ Feb 6 2004, 03:45 PM) Hey J... Could be the adjuster on the rear of the torsion bar is a little loose fitting (IMG:style_emoticons/default/wink.gif) ;) Nah... if that was the case, he'd hear a clunking noise (IMG:style_emoticons/default/biggrin.gif) cheers, Jeroen |
Joe Bob |
Feb 6 2004, 10:04 AM
What is your ride height? 914s don't like to be too low.....
F4i |
Feb 6 2004, 10:05 AM
914 DOG! Group: Benefactors Posts: 482 Joined: 22-December 03 From: AB Canada Member No.: 1,460 |
I have had this on a different car it turned out to be tie rod ends.
Mueller |
Feb 6 2004, 11:33 AM
just guessing here:
too fast, cold ground, cold tires (not evenly heated due to alignment/corner balance or lack of), oil on new asphalt.........take it easy, that car of yours is too damn nice to go getting up close and personal with the guard rails (IMG:style_emoticons/default/MDB2.gif) |
SirAndy |
Feb 6 2004, 02:46 PM
QUOTE(Jeroen @ Feb 6 2004, 06:33 AM) Can you try to describe it a little better? the whole car is slightly rocking left/right like a baby-crib ... like you're sitting in it and someone is rocking the car by pushing on one side of the roof. hard to describe, i guess ... <_< Andy |
SirAndy |
Feb 6 2004, 02:47 PM
QUOTE(F4i @ Feb 6 2004, 08:05 AM) I have had this on a different car it turned out to be tie rod ends. hmmm, that could be it. still have the original 911 tie-rods (not turbo) and original rubber bushings. they might be toast ... but, would that result in the described behavior ??? Andy |
fiid |
Feb 6 2004, 02:55 PM
Turbo Megasquirted Subaru Member Group: Members Posts: 2,827 Joined: 7-April 03 From: San Francisco, CA Member No.: 530 Region Association: Northern California |
I have felt the senastion you describe, but not in a 914....
Could it be that your front suspension just isn't super tight - so your shocks are a little soft, and you only have 19mm torsion bars right?? WHat do you have for a sway bar? What springs do you have in the rear? For street tires, I think you might just be pushing the limits - I usually consider it safe to do double the posted limit for any given bend (bends only) - if you toook that thing at a real 100 - you were probably doing pretty well to make it....? Did you tap the brakes to plant the nose before the turn? |
SirAndy |
Feb 6 2004, 03:05 PM
QUOTE(fiid @ Feb 6 2004, 12:55 PM) Did you tap the brakes to plant the nose before the turn? it's not a very tight turn, more of a nice loooooong sweeper, for those who know the area, i took hwy 13 towards berkeley and merged onto 24 towards oakland. it's the offramp (to the left) off 13 onto 24. nice new asphalt, so no bumps on the road .... no, i did not tap the brakes, came downhill at about 110 mph, lifted throttle for a brief second, then into the turn with steady gas @ about 100 mph, went through like on rails, just the rocking was a bit irretating (sp?) .... i don't know the torsion bar size, stock 911 '86 carrera frontend. stock 911 black (boge?) shocks, 22mm swaybar on fairly soft (about 1" in from the front), 180lbs progressive springs in the rear. i wasn't accelerating through the corner, just holding it steady ... the car was NOT sliding, tires stuck like glue ... (IMG:style_emoticons/default/confused24.gif) Andy |
fiid |
Feb 6 2004, 07:50 PM
Have you taken it at that speed in a different car?? Is it really smooth - or is it just smooth at 60?
Was it windy? I'm clutching at straws now.... |
Gint |
Feb 6 2004, 10:28 PM
Mike Ginter Group: Admin Posts: 16,083 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
Like Fiid said, it could have been as simple as wind at that speed. Or some undulations in the pavement that you couldn't quite see.
SirAndy |
Feb 6 2004, 11:57 PM
QUOTE(Gint @ Feb 6 2004, 08:28 PM) Like Fiid said, it could have been as simple as wind at that speed. Or some undulations in the pavement that you couldn't quite see. no wind. i would have felt any uneven spots in the road in the steering. nada, just the car rocking (IMG:style_emoticons/default/huh.gif) i suspect either worn bushings or something loose in the suspension, like the tie-rod ends or something. guess it's time for a suspension weekend, Andy |
Jeroen |
Feb 7 2004, 05:56 AM
If you didn't feel it through the steeringwheel, bumpsteer is out
Tie-rods too... you'd felt it on the steering wheel I think that leaves you either bad bushings and/or bad shocks... cheers, Jeroen |
Brad Roberts |
Feb 7 2004, 11:29 AM
I think he left out the fact that the chassis is cracked at the front control arm mounts. I'm almost 100%+ that the car needs front shocks.
Oh.. James.. the bounce test works on stock 914's (just not as well as a Buick) (IMG:style_emoticons/default/laugh.gif) B |
Lo-Fi Version | Time is now: 10th June 2024 - 03:47 AM |
