jea69 |
doing unspeakable things to iron ![]() ![]() Group: Members Posts: 51 Joined: 13-March 08 From: norway Member No.: 8,811 Region Association: Scandinavia ![]() |
hi all (IMG:style_emoticons/default/smile.gif) i just bought a center console for my 70/4 (IMG:style_emoticons/default/piratenanner.gif) , installing it i had to remove the pushbutton for the washerpump installed by the PO , looking closer at the original wiperswitch on the dash, it seems like it have a push center ,feels like its spring loaded, is this a switch? (IMG:style_emoticons/default/confused24.gif) if so can it replace the one i took off(broke)? (the switch i took off is just a "under the dash bolt on cheepo switch)
dr914@autoatlanta.com |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,188 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None ![]() |
yes and yes
jea69 |
yes and yes thanks (IMG:style_emoticons/default/smile.gif) ill pull it and see if i can figure it out using my voltmeter |
Lo-Fi Version | Time is now: 19th July 2025 - 10:06 AM |
