Heater Box Cable Connector, where could I find something that would work? |
vesnyder |
Oct 18 2008, 09:55 PM
Senior Member Group: Members Posts: 680 Joined: 14-April 05 From: Cleveland, OH Member No.: 3,933 |
I misplaced the special connector that holds the heater cable into the heater box that controls the heat. Is this a normal connector that I can find elsewhere? Let me know if you know what I am talking about and if not I will post a pic.
Thanks |
bdstone914 |
Oct 18 2008, 10:59 PM
bdstone914 Group: Members Posts: 4,537 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
I misplaced the special connector that holds the heater cable into the heater box that controls the heat. Is this a normal connector that I can find elsewhere? Let me know if you know what I am talking about and if not I will post a pic. Thanks It is also a VW part. https://www.vwparts.net/311129777.html Bruce https://www.vwparts.net/311129777.html |
Bruce Allert |
Oct 19 2008, 12:37 AM
Hellions asleep Group: Members Posts: 3,289 Joined: 19-March 03 From: Eagle Creek, Orygun Member No.: 441 Region Association: Pacific Northwest |
You should be able to go to most any "discount Import Auto Parts" store that sells VW stuff & pick that up. I always bought most everything from them.
......b |
Joe Owensby |
Oct 19 2008, 09:42 AM
JoeO Group: Members Posts: 527 Joined: 7-January 06 From: Spartanburg, SC Member No.: 5,385 Region Association: South East States |
If you are talking about the piece that connects the cable to the pivot, you can get them at a local auto parts. Look in the miscellaneous parts section for a pack of these. They look like a small rod with a hole drilled through them and a screw inserted. They have a small hole drilled cross wise though them for the cable. I had to open up the cross drilled hole a little. JoeO
iamchappy |
Oct 19 2008, 10:17 AM
It all happens so fast! Group: Members Posts: 4,893 Joined: 5-November 03 From: minnetonka, mn Member No.: 1,315 Region Association: Upper MidWest |
Hardware store.
Lo-Fi Version | Time is now: 10th June 2024 - 09:27 AM |
