Replacing Cables, speedo, clutch, accel |
2-OH! |
Feb 9 2004, 02:19 PM
Senior Member Group: Members Posts: 552 Joined: 17-October 03 From: Santa Clarita, Kalifornication Member No.: 1,253 |
Clutch Cable...
Accelerator Cable... Pelican list a product called "Terry" cables...Are they good?, better?, or should I just find OEM... 2-OH! |
seanery |
Feb 9 2004, 02:35 PM
waiting to rebuild whitey! Group: Retired Admin Posts: 15,854 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None |
Terry's are better.
maf914 |
Feb 9 2004, 02:43 PM
Not a Guru! Group: Members Posts: 3,049 Joined: 30-April 03 From: Central Florida Member No.: 632 Region Association: None |
QUOTE(seanery @ Feb 9 2004, 12:35 PM) Terry's are better. Cheaper, too! (IMG:style_emoticons/default/laugh.gif) Mike |
Matt Romanowski |
Feb 9 2004, 07:11 PM
Senior Member Group: Members Posts: 878 Joined: 4-January 04 From: Manchester, NH Member No.: 1,507 |
The Terry's are nicer. Very nice ends and a better quality cable.
Matt |
swood |
Feb 9 2004, 08:28 PM
Senior Member Group: Members Posts: 1,839 Joined: 6-February 03 From: Strong Beach Member No.: 251 Region Association: None |
Note to self (and you):
The Terry clutch cable apperantly has to be cut back 1" and then re-threaded to take up the slack. It's 1" too long. This is from RedBeard. Can anyone else confirm? |
Brad Roberts |
Feb 10 2004, 12:23 AM
914 Freak! Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None |
Run it. I have never cut one. If there is a problem Terry will correct it (unlike other manufacturers) They are in SoCal. I had them start making 9146 cables 3-4 years ago. Sent them a stock one and they duped it in the good stuff. As far as them being long.. I have seen engines sitting .5 to 1.0 inches OFF where they should be.
B |
fraggle00 |
Feb 10 2004, 07:17 PM
Newbie Group: Members Posts: 35 Joined: 27-September 03 From: Boise, ID Member No.: 1,202 |
I used all Terry cables from Pelican.
Advice: thread some crafting ribbon to the pedal end before you pull the old cables out. Then you can use it to pull the new ones through. The ribbon is easy to tie, thin, and strong as hell so it won't break. |
Lo-Fi Version | Time is now: 13th June 2024 - 11:46 PM |
