Transmission Help !!!, How to remove Pin... |
2-OH! |
Feb 14 2004, 08:08 PM
Senior Member Group: Members Posts: 552 Joined: 17-October 03 From: Santa Clarita, Kalifornication Member No.: 1,253 |
Page 76, Item 20...The Haynes manual...
says "remove the stretch bearing bolt (expansion bolt)" but it does not tell me how to get the "Lock Pin" out of the speedo drive, first... It appears to be a roll pin that needs to be drifted out but you can't get to it due to the entire assembly is recessed into the 1st gear Guide Sleeve... Even after the speedo drive is removed, how do you un-torque the "stretch bearing bolt"... All this just to change the 1st gear synchro... Help !!! 2-OH! |
Brad Roberts |
Feb 14 2004, 08:09 PM
Long socket. It is the same size as the axle nut (I forget what that size is..maybe 32mm)
I never remove the pin. B |
rdracrdave |
Feb 15 2004, 12:53 AM
Newbie Group: Members Posts: 34 Joined: 5-May 03 From: Cincinnati,Ohio Member No.: 653 |
30 mm deep socket. Available at Sears , Autozone , Pepboys
JWest |
Feb 15 2004, 08:09 AM
Senior Member Group: Members Posts: 1,662 Joined: 6-January 03 From: Fort Worth, TX Member No.: 97 Region Association: None |
QUOTE(rdracrdave @ Feb 15 2004, 12:53 AM) 30 mm deep socket. Available at Sears , Autozone , Pepboys <ect. Dave (IMG:style_emoticons/default/agree.gif) The 30mm deep socket is used on a lot of FWD front axle nuts, so it is a pretty common tool. |
Lo-Fi Version | Time is now: 7th June 2024 - 06:55 AM |
