Weber 48 IDF Carbs |
914 Monster |
Jan 21 2009, 09:17 PM
Newbie Group: Members Posts: 27 Joined: 14-April 08 From: Los Angeles Member No.: 8,924 Region Association: Southern California |
Can anybody please inform me about the 48 IDF weber carbs and which IDF weber carb provides more top performance?
McMark |
Jan 22 2009, 12:17 AM
48 mm carbs are huge. You'd better have an absolute monster motor to support those carbs. We need more information about the motor they're going on before making any predictions.
Type 4 Unleashed |
Jan 22 2009, 02:13 AM
CREATIVE TYPE lV ENGINEERING Group: Retired Members Posts: 787 Joined: 20-June 04 From: Aliso Viejo, ca Member No.: 2,231 Region Association: None |
Here is some European thinking on carburator size.
QUOTE When building a big t-4 engin the main issue is to get big carbs, since a 48mm carb is about maksimum for a 1800ccm engin. We uses 48 carbs on 1600cc rally engin with a increase og 10-20hp witout loosing any bootom end torque. So a 2.9cc engin would need 58mm GB carbs to work at its maksimum, I used them on my 2770 with great power increase. |
Jake Raby |
Jan 22 2009, 02:38 AM
Engine Surgeon Group: Members Posts: 9,394 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States |
One of the fastest ways to create an engine with a less than friendly usable RPM range is to over carb it.. The TIV is a velocity engine and doesn't need massive amounts of intake volume to make it's best power.
we make 200HP from less than 2.3 liters and 9.5:1 CR with only a 44mm IDF carburetor with a stock 36mm venturi. These engines have a TON of usable power and don't just perform well on the dyno, they have an RPM range thats usable from 2-6.5K RPM and thats the key to making a fast car. I don't use a 48mm carb till we exceed 2.7 liters, but this is with engines that feature my design thats greatly different from other tuners. the bottom line is big carbs perform best on big engines and unless you have the budget for a big engine the big carbs will just be hard to tune and make usable power at an RPM that the engine isn't generally operated at. That means their use is virtually worthless on anything of "sane" displacement. |
johnnie5 |
Jan 22 2009, 05:33 AM
914 lover Group: Members Posts: 375 Joined: 14-October 08 From: San Diego, CA Member No.: 9,644 Region Association: Southern California |
One of the fastest ways to create an engine with a less than friendly usable RPM range is to over carb it.. The TIV is a velocity engine and doesn't need massive amounts of intake volume to make it's best power. we make 200HP from less than 2.3 liters and 9.5:1 CR with only a 44mm IDF carburetor with a stock 36mm venturi. These engines have a TON of usable power and don't just perform well on the dyno, they have an RPM range thats usable from 2-6.5K RPM and thats the key to making a fast car. I don't use a 48mm carb till we exceed 2.7 liters, but this is with engines that feature my design thats greatly different from other tuners. the bottom line is big carbs perform best on big engines and unless you have the budget for a big engine the big carbs will just be hard to tune and make usable power at an RPM that the engine isn't generally operated at. That means their use is virtually worthless on anything of "sane" displacement. I had a buddy of mine recommend that if I put 44's on the 2056 I would be better off. I told him the motor seems to be running pretty darn good with 40's , and it just seems to me 44's on a 2056 would be a little overkill. It did make me curious as to what difference the motor would have with 44's on it. Am I correct, would 44's on a 2056 be too much carb? |
Al Meredith |
Jan 22 2009, 09:34 AM
Senior Member Group: Members Posts: 961 Joined: 4-November 04 From: Atlanta, ga Member No.: 3,061 |
I had 40MMs on my 2056 when I built it . My Son wanted to see how it would perform with 44's. We installed EMPI's 44's and he says he can feel the improvement at high RPM. I know it is running rich but it is cold in Atlanta and I don't want to rejet until it gets warmer. The flat spot at about 3000 RPM is gone with the EMPIs , that could be the rich mixture. Oh! at the Dyno it does show rich now. I'll have a better responce whenit gets warmer.
sww914 |
Jan 22 2009, 09:54 AM
Advanced Member Group: Members Posts: 2,439 Joined: 4-June 06 Member No.: 6,146 Region Association: None |
You'll always be happier with carbs that are too small than you ever will with carbs that are too large. Just because they'll bolt up and they're larger doesn't mean that it's a good thing to do.
Some 22" wheels with spinners might bolt up, they're large too, but that's not a good idea either. |
JmuRiz |
Jan 22 2009, 11:42 AM
914 Guru Group: Members Posts: 5,435 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region |
Does seem like a huge carb, I thought the Delorto 45's I had were huge...even though I'll probably never put them on my car.
I'd trust what Jake says about carb-size and performance, he's tried a various number of combos and actually has a dyno to test them. |
jmill |
Jan 22 2009, 12:01 PM
Green Hornet Group: Members Posts: 2,449 Joined: 9-May 08 From: Racine, Wisconsin Member No.: 9,038 Region Association: Upper MidWest |
You'll always be happier with carbs that are too small than you ever will with carbs that are too large. Just because they'll bolt up and they're larger doesn't mean that it's a good thing to do. (IMG:style_emoticons/default/agree.gif) 90% of your driving is done in the low to mid RPM range. A smaller carb will have better throttle response and drivability in these ranges. A larger carb will provide better high RPM performance but it's at the expense of throttle response and drivability. I'd stick with the smaller carb almost every time unless I was building a drag car. |
johnnie5 |
Jan 23 2009, 09:47 AM
sww914,
Whats wrong with 22's, DAWG... Attached image(s) |
IronHillRestorations |
Jan 23 2009, 03:14 PM
I. I. R. C. Group: Members Posts: 6,732 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
Yee hawww a couple o buck boards!
Back OT, you are getting good advice, don't over carburate your engine. |
r_towle |
Jan 23 2009, 03:33 PM
Custom Member Group: Members Posts: 24,594 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
I had 40MMs on my 2056 when I built it . My Son wanted to see how it would perform with 44's. We installed EMPI's 44's and he says he can feel the improvement at high RPM. I know it is running rich but it is cold in Atlanta and I don't want to rejet until it gets warmer. The flat spot at about 3000 RPM is gone with the EMPIs , that could be the rich mixture. Oh! at the Dyno it does show rich now. I'll have a better responce whenit gets warmer. Drive the car. Define upper end for yourself. At our age its probably lower than what your son feels. You can put in a rev limiting rotor to save the motor from your son...I did and he never knew. Big valves and big carbs will only kick in from 4500-5500 rpm and then your valves start to float...unless you have stiffer valve springs, lighter valves, etc etc. Track car, living at those RPM's for 20 minutes...you bet. Street car that stops and goes...never. I have tried both...the 40mm carb, properly jetted is really a nice match for these motors under 2.2 liter...that seems to be about the limit. Intake air speed in the lower range is terrible with big valves and big carbs...or one of those alone..even worse. Then the air/fuel mixture stands a good chance of deatomizing with the fuel returning to a liquid..then fouled plugs are the result. Rich |
96740 |
Mar 25 2009, 06:02 PM
Member Group: Members Posts: 328 Joined: 10-March 08 From: Thousand Oaks, CA Member No.: 8,791 Region Association: Southern California |
So.Cal.914 |
Mar 25 2009, 06:41 PM
"...And it has a front trunk too." Group: Members Posts: 6,588 Joined: 15-February 04 From: Low Desert, CA./ Hills of N.J. Member No.: 1,658 Region Association: None |
These guys would not lead you wrong. Keep your 40's and have fun. (IMG:style_emoticons/default/driving.gif)
96740 |
Mar 25 2009, 09:26 PM
I'm in the market for some new carbs. I now have on some Euro bastard child 40 idf models that came with the car and my mechanic is trying his best to get them to work for me a while longer.
He tells me after my engine rebuild that if I do get some new carbs, to look for some nice Delorto's. If not than he recommends I up to the 44's. The engine as it is now is a 2056 with some aggressive CB Performance cams and springs and a set of KB pistons. My guess is that a pair of new (Spanish) 40's would be fine. Could the 44's work well? Conventional wisdom say's NO NEED. (IMG:style_emoticons/default/confused24.gif) |
Chris Hamilton |
Mar 25 2009, 10:31 PM
Senior Member Group: Members Posts: 611 Joined: 7-March 06 From: Berkeley, CA Member No.: 5,687 |
If anyone has an old useless set of 48mm webers they're throwing out I'll take them off your hands for you. (IMG:style_emoticons/default/confused24.gif)
koozy |
Mar 26 2009, 01:16 AM
Senior Member Group: Members Posts: 651 Joined: 21-July 07 Member No.: 7,931 Region Association: None |
me too...
schreiber |
Mar 27 2009, 10:10 AM
Member Group: Members Posts: 137 Joined: 26-June 07 From: Huntsville, AL Member No.: 7,843 Region Association: South East States |
This thread seems closely-related to a question I asked a day or two ago.
HIJACK (IMG:style_emoticons/default/beerchug.gif) |
DBCooper |
Mar 27 2009, 11:03 AM
14's in the 13's with ATTITUDE Group: Members Posts: 3,079 Joined: 25-August 04 From: Dazed and Confused Member No.: 2,618 Region Association: Northern California |
If anyone has an old useless set of 48mm webers they're throwing out I'll take them off your hands for you. (IMG:style_emoticons/default/confused24.gif) Me too. Or 44 IDF's, 48 IDA's, 45 DRLA's or any size DHLA's. I have no particular conviction, will help you get rid of any of these models. |
Lo-Fi Version | Time is now: 16th June 2024 - 10:28 PM |
