highways |
Senior Member ![]() ![]() ![]() Group: Members Posts: 613 Joined: 18-June 05 From: Los Angeles, CA Member No.: 4,296 ![]() |
When I pull out my headlight switch with the instrument dimmer turned to 'off' everything works fine. When i turn up the instrument panel dimmer... instruments light up but my voltage meter progressively goes backwards ending up pegged at under 8volts and the battery gets drained as I drive at night. Is this indicating a failed headlight switch? Or do I have some wires crossed somewhere?
highways |
(IMG:style_emoticons/default/icon_bump.gif) fail or no fail? Looking for someone who knows symptoms of failing headlight dimmer switch. |
904svo |
904SVO ![]() ![]() ![]() Group: Members Posts: 1,126 Joined: 17-November 05 From: Woodstock,Georgia Member No.: 5,146 ![]() |
Try cleaning the contacts on fuse #9 they might be dirty.
Lo-Fi Version | Time is now: 12th July 2025 - 08:30 AM |
