Reasonable price on ESAB Easy-Grind .023 |
charliew |
Feb 9 2009, 10:12 AM
Advanced Member Group: Members Posts: 2,363 Joined: 31-July 07 From: Crawford, TX. Member No.: 7,958 |
Does anyone have a source for easy-grind. The prices locally is about 60.00 for a ten lb. roll of .023. That seems pretty steep just to get a more malleable weld.
J P Stein |
Feb 9 2009, 10:27 AM
Irrelevant old fart Group: Members Posts: 8,797 Joined: 30-December 02 From: Vancouver, WA Member No.: 45 Region Association: None |
I bought some about 10 years ago and IIRC it was not cheep.....30-40 bucks. Worth every nickel tho. I've used half (WAG) the spool). Bout the only folks that buy the stuff are body pros...not a big market.
A steel worker friend (night supe) got it thru his company at their discount. |
rick 918-S |
Feb 9 2009, 03:03 PM
Hey nice rack! -Celette Group: Members Posts: 20,484 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
I asked about it at the welding supply store. They told me there was no difference in mild steel welding wire. I used to buy easy grind when I had my shop through the body supply store. They told me the same thing as the welding supply. (IMG:style_emoticons/default/confused24.gif)
Todd Enlund |
Feb 9 2009, 03:23 PM
Resident Photoshop Guru Group: Members Posts: 3,251 Joined: 24-August 07 From: Laurelhurst (Portland), Oregon Member No.: 8,032 Region Association: Pacific Northwest |
I asked about it at the welding supply store. They told me there was no difference in mild steel welding wire. I used to buy easy grind when I had my shop through the body supply store. They told me the same thing as the welding supply. (IMG:style_emoticons/default/confused24.gif) So, it's easier to grind in the same way as your car is faster after you wash it? |
J P Stein |
Feb 9 2009, 04:41 PM
Your car body is made out of cold forming steel.....something like A36. It has a tensile strength of around 36K PSI. The "normal" weld wire has a strength of somewhere upwards of 60K psi tensile.....this means it's harder on the Rockwell or Brinell scale. Easy Grind is soft....not quite as soft as the body metal, me thinks, but close. It is considerably.....ah... easier to grind which makes it easier to fair into the surounding metal.....and to clean up the mess you've made with your stinger....thas important to me. (IMG:style_emoticons/default/biggrin.gif)
It's not too shinney for structual welds tho. |
charliew |
Feb 10 2009, 12:25 PM
Softer means more forgiving when you are reshaping the surrounding areas and less prone to getting fractures you can't see till about three years later when the paint starts to bubble. These cars twist a lot and thats why you almost never find fiberglass parts that haven't cracked either where they are bonded on or close by. On unibody cars all of the body panels are there to support the suspension and the cabin and drive line weight.
Lo-Fi Version | Time is now: 6th June 2024 - 12:56 PM |
