Proportioning Valve, Stock, Adjustable, or Tee |
ventedrib |
Feb 25 2009, 02:28 PM
Member Group: Members Posts: 104 Joined: 10-August 08 From: Monroe La. Member No.: 9,406 Region Association: South East States |
I have 911 front suspention with A calipers and stock 914 4 rear calipers. Should I use stock proportioning valve an adjustable one or a Tee. I thought a tee might work fine with the bigger brakes up front and the small in the back what do you think.
ventedrib |
Feb 25 2009, 02:31 PM
I have 911 front suspention with A calipers and stock 914 4 rear calipers. Should I use stock proportioning valve an adjustable one or a Tee. I thought a tee might work fine with the bigger brakes up front and the small in the back what do you think. |
Lo-Fi Version | Time is now: 13th June 2024 - 05:41 AM |
