1.8 Cylinder Head Tip, Do I Rebuild or go for the big bucks! |
nowlings |
Mar 1 2009, 10:08 PM
Newbie Group: Members Posts: 28 Joined: 21-March 07 From: sacramento Member No.: 7,615 |
Ok.. while checking for a loss of power I found I have a #1 cylinder exhaust valve that appears to have a collapsed seat. In looking at pulling the heads to have them re-done, I can go to the local machine shop and have them re-worked (any recommendations in Sacramento?) or going with new. I was looking at air cooled classics' web site and they have new heads for $1600 usd... OUCH! They explain how great and long lived their heads are. Question is does this a good alternative or does it make sense over the long run versus just taking them to the local machine shop for a rebuild. This is a stock motor running on stock FI.
Thanks (IMG:style_emoticons/default/wacko.gif) |
messix |
Mar 2 2009, 12:23 AM
AKA "CLUTCH KILLER"! Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest |
bump
Cap'n Krusty |
Mar 2 2009, 02:12 AM
I suggest you send them to a specialist such as Competition Engineering in Lake Isabella or Engine Machine Service in LA. First they'll tell you if they're gonna be able to fix what you have, then how much it'll cost. I've been doing these cars for 36 years, and I can tell you with certainty that you're not gonna get what you need at just any auto machine shop. Figure $1200 and up for the pair. Do it right, do it once. While you're at it, better correct the heat problem. Because they're gonna have to surface the heads, you'll need to calculate the new cylinder volume and shim the cylinders to get manageable compression. The Cap'n
justme |
Mar 2 2009, 06:03 AM
Member Group: Members Posts: 187 Joined: 1-January 07 From: southampton ma atlantic northeast Member No.: 7,413 Region Association: North East States |
Check oyt bugpatch.com
Easy to work with & have been doing them for years. A few options also. Phil |
914Sixer |
Mar 2 2009, 07:21 AM
914 Guru Group: Members Posts: 8,906 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
AMC makes aftermarket 1.8/2.0 Bus heads. Jake and Len used these heads originally before they started making the CNC heads. These were the basis for the LE 180 series heads. The springs and studs are weak in these heads according to them and must be replaced. These heads are available NEW from autohausaz.com. Cost is about $415 each. You have to go to the VW Bus 76 model and look them up under engine parts. This is another option and you will get NEW parts.
nowlings |
Mar 2 2009, 11:05 AM
I suggest you send them to a specialist such as Competition Engineering in Lake Isabella or Engine Machine Service in LA. First they'll tell you if they're gonna be able to fix what you have, then how much it'll cost. I've been doing these cars for 36 years, and I can tell you with certainty that you're not gonna get what you need at just any auto machine shop. Figure $1200 and up for the pair. Do it right, do it once. While you're at it, better correct the heat problem. Because they're gonna have to surface the heads, you'll need to calculate the new cylinder volume and shim the cylinders to get manageable compression. The Cap'n Thanks for the suggestions! |
Lo-Fi Version | Time is now: 9th June 2024 - 02:57 PM |
