914 drain hose, Substitute |
nigolusa |
Mar 4 2009, 09:52 PM
nigolusa Group: Retired Members Posts: 157 Joined: 10-November 08 From: los angeles Member No.: 9,737 Region Association: Southern California |
Does anybody know if I can use a substitute for the drain hose #13?
(IMG:style_emoticons/default/beer3.gif) Attached image(s) |
schreiber |
Mar 4 2009, 09:58 PM
Member Group: Members Posts: 137 Joined: 26-June 07 From: Huntsville, AL Member No.: 7,843 Region Association: South East States |
Does anybody know if I can use a substitute for the drain hose #13? (IMG:style_emoticons/default/beer3.gif) Yes, you can find similar tubing at your big home omprovement stores. Also, try using the search function here - lots of related info available. |
nigolusa |
Mar 4 2009, 10:05 PM
Does anybody know if I can use a substitute for the drain hose #13? (IMG:style_emoticons/default/beer3.gif) Yes, you can find similar tubing at your big home omprovement stores. Also, try using the search function here - lots of related info available. What is the diameter equivalent in inches? |
jim_hoyland |
Mar 4 2009, 10:06 PM
Get that VIN ? Group: Members Posts: 9,313 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
For a long time, Osh or Orchard Supply had it. They called it irrigation hose. It was $25 for 20 feet. Exact same size.
Last week, i saw some at Home Depot in the garden section. Maufacturer is Beckett. Here's a pic: Attached image(s) |
nigolusa |
Mar 4 2009, 10:09 PM
For a long time, Osh or Orchard Supply had it. They called it irrigation hose. It was $25 for 20 feet. Exact same size. Last week, i saw some at Home Depot in the garden section. Maufacturer is Beckett. Here's a pic: THank you!!!!! (IMG:style_emoticons/default/cheer.gif) http://www.homedepot.com/webapp/wcs/stores...=10000003+90401 |
zonedoubt |
Mar 5 2009, 12:01 AM
Canadian Member Group: Members Posts: 668 Joined: 14-May 03 From: Vancouver, BC Member No.: 696 Region Association: Canada |
I bought mine here: http://www.greenlinehose.com/
"G930… CORRUGATED BILGE HOSE" $0.60/ft and has a nice "clamping cuff" to fit over the funnels. It is a bit wider diameter but is a decent solution. Check your local Yellow Pages for hose suppliers. |
bandjoey |
Mar 5 2009, 12:06 AM
bandjoey Group: Members Posts: 4,926 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
Mine is a 4ft piece of washing machine drain hose from Home depot. Same diameter, and the end is smooth without ridges for about 4", letting the tube poke through the rubber grommet in the tin real smooth. Hacksaw cut to length (IMG:style_emoticons/default/sawzall-smiley.gif)
highways |
Mar 5 2009, 02:49 AM
Senior Member Group: Members Posts: 613 Joined: 18-June 05 From: Los Angeles, CA Member No.: 4,296 |
I used the irrigation hose, and had to make a little inner-tube joiner splice out of vacuum hose to attach irrigation hose to the funnels... had to skip the spring clamp. (IMG:style_emoticons/default/sad.gif)
AvalonFal |
Mar 11 2009, 03:50 PM
Member Group: Members Posts: 483 Joined: 3-July 05 From: Southern New Jersey Coast Member No.: 4,367 Region Association: MidAtlantic Region |
Anybody know if the spring clamps (part #12) are available anywhere?
Paul |
southernmost914 |
Mar 11 2009, 04:03 PM
KEY WEST/HAVANA Tunnel Authority Group: Members Posts: 338 Joined: 16-October 07 From: Key West/ St. Augie, Fl USA Member No.: 8,234 Region Association: South East States |
Bilge hose at Westmarine.
Steve |
Cevan |
Mar 11 2009, 06:20 PM
Senior Member Group: Members Posts: 1,079 Joined: 11-December 06 From: Western Massachusetts Member No.: 7,351 |
Isn't the fresh airbox drain hose the same?? There must be a ton around with all the cars that have been dismantled.
zonedoubt |
Mar 11 2009, 11:00 PM
Lo-Fi Version | Time is now: 31st May 2024 - 06:48 PM |
