1970 1.7 Motor teardown, Water in motor |
knuckledrgr914 |
Mar 31 2009, 07:57 PM
Newbie Group: Members Posts: 46 Joined: 17-June 08 From: Meridian Member No.: 9,180 Region Association: None |
I guess the only place to start with this thread is the beginning... I have a friend who purchased a 914 to toy with, and he talked me into getting one also (didn't take much talking to peak my interest (IMG:style_emoticons/default/ohmy.gif)). Well I ended up with four 914's in a package deal ('70, '72, '72, '74). Only one of them actually runs ('74 1.8 FI).
I am not very mechanical, but I have found the best way to learn something is to do it! I was advised by the person I bought the vehicles from that the '70 had ~ $4,000.00 worth of work done to the motor. The problem is the prior owner removed the carbs and for some reason did not protect the openings from the weather and water got into the motor. I dropped the motor and transmission and took the motor to a friend's house who has had some experience with VW's. We took the motor apart and cracked the case. My questions.... What is the recommended procedure for removing rust from cylinders, jugs (?), valves, etc... I will post pictures shortly of the specific areas of rust... I tried attaching a pic to this post, but I was prompted that I reached the maximum allowed size for the post and to reduce the size of the pic. Reccomendations to reduce the size of pics? Thanks, Brad |
knuckledrgr914 |
Mar 31 2009, 09:04 PM
From looking at the cam, it has engravings that state "Replaces 021 109 111C". Can anyone tell me if this is the standard size cam for a 1.7?
Thanks, Brad |
McMark |
Mar 31 2009, 09:13 PM
Any old or worn cylinders that are going to be reused should be honed and new rings put on the piston.
knuckledrgr914 |
Apr 1 2009, 12:52 PM
Thanks McMark! I notice you are part of the Admin Group... I am trying to attach 1 photo (a little over 1m) and I am receiving the message:
"The total filespace required to upload all the attached files is greater than your per post or global limit. Please reduce the number of attachments or the size of the attachments." The photo is digital from a Cannon Powershot SD300. Ideas? Brad |
Todd Enlund |
Apr 1 2009, 01:17 PM
Resident Photoshop Guru Group: Members Posts: 3,251 Joined: 24-August 07 From: Laurelhurst (Portland), Oregon Member No.: 8,032 Region Association: Pacific Northwest |
Thanks McMark! I notice you are part of the Admin Group... I am trying to attach 1 photo (a little over 1m) and I am receiving the message: "The total filespace required to upload all the attached files is greater than your per post or global limit. Please reduce the number of attachments or the size of the attachments." The photo is digital from a Cannon Powershot SD300. Ideas? Brad I think the limit is somewhere around 400-450 Mb per post... you'll need to resize the photo. 800x600 pixels, or 640x480, are good sizes that will get you in the right range. |
Cupomeat |
Apr 1 2009, 01:55 PM
missing my NY 914 in VA Group: Members Posts: 1,336 Joined: 26-November 07 From: Oakton VA Member No.: 8,376 Region Association: MidAtlantic Region |
Here is a lovely example of water in the motor. In this case, the cylinders were not worth saving and we definitely replaced all the bearings. The best thing to do would be to pull it all apart, clean every spot/bit of rust and then measure everything. Anywhere that the cleaning was significant is a place to concern yourself with the most. I've found this very interesting jelly like goo in the bottom of crank cases in engines that sat and had water intake. I have a mild interest in what formulated it. Good luck! |
McMark |
Apr 1 2009, 04:28 PM
I don't have any leads on the goo/slime/jelly, but I've seen it in other motors. Like the water soaked 1.7 I just tore down.
If you're going for a full rebuild, just replace the pistons/cylinders with a 96mm set, but you'll have to do a little machining to the 1.7 heads or get 1.8/2.0 heads. Clean everything really well. |
ConeDodger |
Apr 1 2009, 04:34 PM
Apex killer! Group: Members Posts: 23,611 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
I don't have any leads on the goo/slime/jelly, but I've seen it in other motors. Like the water soaked 1.7 I just tore down. If you're going for a full rebuild, just replace the pistons/cylinders with a 96mm set, but you'll have to do a little machining to the 1.7 heads or get 1.8/2.0 heads. Clean everything really well. Geez! you took that thing apart already? Aren't you the go-getter? Do a how-to on replacing that dipstick tube. I bet other engine cases have been thrown because of that. |
knuckledrgr914 |
Apr 1 2009, 08:19 PM
[/quote]
I think the limit is somewhere around 400-450 Mb per post... you'll need to resize the photo. 800x600 pixels, or 640x480, are good sizes that will get you in the right range. [/quote] Thanks Todd! What should I use to resize the photo? Is there a freeware or shareware I can download to accomplish this? Brad |
Dave_Darling |
Apr 1 2009, 10:32 PM
Google for "irfanview" for a program that will resize pictures.
--DD |
SirAndy |
Apr 1 2009, 11:26 PM
Resident German Group: Admin Posts: 41,676 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
I think the limit is somewhere around 400-450 Mb per post... (IMG:style_emoticons/default/wacko.gif) I think the size limit per image is around 300k, which is PLENTY for a JPG ... Reduce your images in size to 1024 x 768 and save them as JPG, compress to 5 (medium) ... Btw. we also have a FAQ that answers all those questions. (IMG:style_emoticons/default/shades.gif) Andy |
dbgriffith75 |
Apr 2 2009, 03:05 PM
TheGrif Group: Members Posts: 509 Joined: 25-July 07 From: Iowa, USA Member No.: 7,945 Region Association: Upper MidWest |
Thanks Todd! What should I use to resize the photo? Is there a freeware or shareware I can download to accomplish this? Brad If you're running Microsoft, paint works. Just copy and paste the photo into paint once it's been saved to your hard drive. OR, right click and select edit- depending on the other programs you have this will take you straight to paint. Then, select all, and I think the shortcut command is control + W, but you want to go to the image drop down menu, select the Stretch/Skew option. In that window there's a way to shrink or increase photo size by percentage. So to shrink, for example, you'd enter 50% for both horizontal and vertical values, hit enter, and the photo will automatically shrink without losing any of the detail. You'll need to manually resize the border of the work area, otherwise you just end up with a tiny photo inside a gigantic white background. Then just save the photo again and it will automatically replace the ginormous original. It's quick and easy and you don't need your internet connection to do it. I've taken 600 kb photos and shrank them down to 40-50 kb without losing any detail using this method. Oh, and by the way, the goo in the bottom of your engine is a combination of rust, oil, and water that's been brewing for a long time. They say oil and water don't mix but when you add rust it comes out looking like that. Also, just a thought, but I don't know if those cylinders are junk. You might try honing one just to see how it turns out. Good luck with your project. (IMG:style_emoticons/default/beerchug.gif) |
knuckledrgr914 |
Apr 2 2009, 10:58 PM
Thanks to all for the help! If I needed this much help with my pics, just imagine how much help I will need with my cars (IMG:style_emoticons/default/w00t.gif) Pics coming soon...
Brad |
knuckledrgr914 |
Apr 5 2009, 07:38 PM
knuckledrgr914 |
Apr 5 2009, 07:41 PM
knuckledrgr914 |
Apr 5 2009, 07:48 PM
and more...
Attached thumbnail(s) |
knuckledrgr914 |
Apr 5 2009, 07:50 PM
and last...
knuckledrgr914 |
Apr 5 2009, 07:52 PM
Any suggestions on cleaning up the heads?
Thanks, Brad |
VaccaRabite |
Apr 5 2009, 08:15 PM
En Garde! Group: Admin Posts: 13,465 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
Take a caliper and measure the diameter of the pistons and report back.
Case and crank look good from here. Cylinders will need serious cleaning and probably re-honed. Knock off thebig stuff and let a machineist do the rest. Pistons will clean up, but will need new rings. I don't know enough to make reccomendations on the heads. If it were me, I'd have the cylinders punched out to 96mm, get a new set of pistons to match, and ahve a nice 1911cc engine. Zach |
jd74914 |
Apr 5 2009, 08:30 PM
Its alive Group: Members Posts: 4,782 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States |
Are those pistons flat topped?
Lo-Fi Version | Time is now: 7th June 2024 - 08:36 PM |
