quick question, putting a 1.8 in a 2.o |
jsayre914 |
Apr 3 2009, 11:01 AM
Speed Up !!! Group: Members Posts: 3,188 Joined: 10-February 08 From: Timonium MD 21093 Member No.: 8,696 Region Association: MidAtlantic Region |
looking at the top end of the 1.8, there are two plastic square connectors on the side with the ecu connector. What are these for??
my 2.0 had a connector for the ecu and the plug for the relay board wich is on the other side. it cant be a heater blower because it is on the passenger side. anybody know. thanks |
SirAndy |
Apr 3 2009, 11:22 AM
Resident German Group: Admin Posts: 41,681 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
anybody know. The 2.0L is D-Jet, the 1.8L is L-Jet. You can't mix-match components between the two. One thing that's probably missing for the 1.8L is the resistor pack that is mounted to the battery tray on L-Jet cars. I ran a 1.8L motor using a 1.7L D-Jet setup for years, that worked just fine. (IMG:style_emoticons/default/bye1.gif) Andy |
Cevan |
Apr 3 2009, 11:27 AM
Senior Member Group: Members Posts: 1,079 Joined: 11-December 06 From: Western Massachusetts Member No.: 7,351 |
Probably your dual relay. Here is a picture to help:
jsayre914 |
Apr 3 2009, 12:04 PM
I need both the resistor pack and dual relay ASAP
can anyone overnight it or guarntee delivery for monday?? HELP!!! |
type47 |
Apr 3 2009, 12:56 PM
Cap'n Krusty |
Apr 3 2009, 02:57 PM
The resistor pack is the same as a bus, but the relay is not. The Cap'n
914Mike |
Apr 5 2009, 02:11 AM
Member Group: Members Posts: 330 Joined: 27-January 03 From: San Jose, CA Member No.: 198 |
The resistor pack is the same as a bus, but the relay is not. The Cap'n I was able to use a bus relay after performing surgery on it. (IMG:style_emoticons/default/smash.gif) IIRC, there is a missing ground pin, or it was moved... Plastic housing popped right open, salvage a pin from the smoked original solder a wire, etc. (IMG:style_emoticons/default/driving.gif) Beat waiting for days to get the right one. (IMG:style_emoticons/default/bye1.gif) |
Lo-Fi Version | Time is now: 10th June 2024 - 08:45 PM |
