Camber Gauge, Do you own or use one? |
kdfoust |
Mar 31 2003, 02:07 AM
Senior Member Group: Members Posts: 694 Joined: 2-January 03 From: Riverside Member No.: 71 Region Association: Southern California |
I'm buying a camber gauge and have been looking at both the Smartcamber gauge (scroll down the page to see the gauge) and the bubble type gauge like this one.
I assume that the smartcamber is the hyper-trick tool for the job, but, it's twice as expensive as the bubble-type gauge. If you've used these (or other) portable camber gauges could you relay that experience? I'm planning to buy this week. I can buy either, it's just that I don't wish to spend more than is needed to accomplish the job... Thanks, Kevin |
Brad Roberts |
Mar 31 2003, 02:15 AM
SmartCamber all the way.
I have used them several times when I dont have a laser setup near by. The only problem I have ever had with them: In the past.. the Smart directions for setting the camber gauge to zero was lacking. This has since changed and the process is well documented with the new version. Make sure you purchase it with all the adapters. I think they sell a extra adapter or two..like a extra wheel holder or something. How are you ?? havent heard from you in awhile. B |
kdfoust |
Mar 31 2003, 11:49 AM
QUOTE(Brad Roberts @ Mar 31 2003, 12:15 AM) SmartCamber all the way. How are you ?? havent heard from you in awhile. B Yeah, that's what I thought. Off to spend more money... (IMG:style_emoticons/default/biggrin.gif) I've been busier than a one-legged man in an ass-kicking contest at my "real job." But it's all good, I'm filling for a couple of patents right now (no I can't say what they are for) which does take up a good bit of effort even at a big corporation with a legal staff and a people to help the process along. Have fun, Kevin |
Dave_Darling |
Mar 31 2003, 12:22 PM
What comes with the Longacre one? If it doesn't have a way to attach it to the wheel, that's an extra expense right there.
I actually went out and bought myself a cheapo "angle finder" (non-digital) at Orchard. Very innaccurate--probably only OK down to about a half-degree--but close enough for very rough checks. I figure I'm just getting it close until I get to a real alignment shop... --DD |
Mueller |
Mar 31 2003, 12:33 PM
Kevin,
I have one that I've used a few times now...I ended up getting the larger frame unit (to use on my 20" truck wheels) along with the Pro 360 module I picked the more expensive Digital SmartLevel Modules for two reasons...1st: I bought the unit with one other person so the cost was split... 2nd: The Pro 360 can be used in more places around the shop and home for setting up other things or construction. |
kdfoust |
Mar 31 2003, 01:12 PM
QUOTE(Mueller @ Mar 31 2003, 10:33 AM) Kevin, I have one that I've used a few times now...I ended up getting the larger frame unit (to use on my 20" truck wheels) along with the Pro 360 module I picked the more expensive Digital SmartLevel Modules for two reasons...1st: I bought the unit with one other person so the cost was split... 2nd: The Pro 360 can be used in more places around the shop and home for setting up other things or construction. Hey, Mueller, what's this PRO360 module? Is that the electronic level that gets attached to the smartcamber or is this an entirely different camber gauge setup? Thanks, Kevin |
Mueller |
Mar 31 2003, 04:29 PM
Smart Racing Products Tool Selection
There are 3 different Digital Levels, I have the mid-level unit. |
anthony |
Aug 19 2004, 11:34 PM
2270 club Group: Benefactors Posts: 3,107 Joined: 1-February 03 From: SF Bay Area, CA Member No.: 218 |
Hey, check out the link that Mueller posted. I think Smart Racing wasn't so smart and forgot to renew their smartcamber domain. (IMG:style_emoticons/default/drooley.gif)
So are the smart camber gauges sufficient to do as good a job as an alignment shop would do? I have three alignments coming up: the Jetta, the 914, and then eventually the 911 if I swap out t-bars. |
J P Stein |
Aug 20 2004, 01:29 AM
Hand level & a broke off piece of tape measure gets me within .25 deg. I take it in for a 4 wheel alignment after any serious suspension work...tain't rocket science, just plane geometry. How much for that gauge????
Brad Roberts |
Aug 20 2004, 02:33 AM
DAMN.. she is not bad...LOL
B |
anthony |
Aug 20 2004, 07:28 AM
QUOTE Hand level & a broke off piece of tape measure gets me within .25 deg. I take it in for a 4 wheel alignment after any serious suspension work...tain't rocket science, just plane geometry. How much for that gauge???? $235 http://www.smartracingproducts.com/ProdCat...l/alsutools.htm With needing to do 2 alignments in the immediate future I'm wondering if they are worth the effort. |
JWest |
Aug 20 2004, 07:56 AM
Senior Member Group: Members Posts: 1,662 Joined: 6-January 03 From: Fort Worth, TX Member No.: 97 Region Association: None |
anthony |
Aug 20 2004, 08:08 AM
Wow, a lot cheaper.
balljoint |
Aug 20 2004, 09:08 AM
914 Wizard Group: Members Posts: 10,000 Joined: 6-April 04 Member No.: 1,897 Region Association: None |
Just waiting for my password. (IMG:style_emoticons/default/rolleyes.gif)
anthony |
Aug 20 2004, 11:47 AM
Just post it here and we'll all paypal you $.25. :-)
Lo-Fi Version | Time is now: 11th June 2024 - 03:18 AM |
