Distributor Removal, what's the trick |
76-914 |
Apr 10 2009, 12:32 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,507 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
(IMG:style_emoticons/default/confused24.gif) How do you access the nut to remove the dist? Sacrifice a wrench? Buy set of crows feet?
tradisrad |
Apr 10 2009, 01:00 PM
Senior Member Group: Members Posts: 985 Joined: 11-September 06 From: San Mateo, CA Member No.: 6,815 Region Association: Northern California |
Loosen the dizzy then rotate it so you can get to the 13mm nut that is holding the clamp then pull it out with the clamp. It can also be removed w/o removing the clamp but the o-ring can hang up on the clamp
7275914911 |
Apr 10 2009, 01:14 PM
Hummmm!!! Group: Members Posts: 756 Joined: 7-May 08 From: Mid-South Member No.: 9,028 Region Association: South East States |
(IMG:style_emoticons/default/confused24.gif) How do you access the nut to remove the dist? Sacrifice a wrench? Buy set of crows feet? If you loosen the Dizzy and turn it sideways you can access the bolt head directly. I am assumming you have Vacumn Canistor on the Dizzy. Mark where the Dizzy is at before rotating it tho so you can get it back real close to time. good luck Ken |
76-914 |
Apr 10 2009, 09:39 PM
Thx, that did it. My first 914. Didn't realize there were two different nuts. Thought it was just that one.
Lo-Fi Version | Time is now: 1st June 2024 - 03:29 AM |
