| zeezee |
Apr 19 2009, 02:20 PM
Member ![]() ![]() Group: Members Posts: 115 Joined: 16-October 08 From: san ramon, ca Member No.: 9,651 Region Association: Northern California |
I found two badly deformed exhaust seals when I pulled the pipes off the manifolds.
Any tips or tricks to making sure the seals and pipes seat correctly? I'm considering a small drop of glue/sealent to stick the copper seal and pipes together properly - hoping this helps with proper alignment when I bolt the pipes into the manifold. |
| Al Meredith |
Apr 19 2009, 05:57 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 984 Joined: 4-November 04 From: Atlanta, ga Member No.: 3,061 |
Always file the part of the exhaust that contacts the copper gasket. You want a smooth flat surface to press against the copper. I usually put some muffler cement on the copper to help hold it up in the head.
| solex |
Apr 19 2009, 06:12 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 789 Joined: 12-January 05 From: Long Island, NY Member No.: 3,439 Region Association: North East States |
I anneal the gaskets prior to fitting/installation and also use copper gasket cement to hold them in place.
| 3d914 |
Apr 19 2009, 07:20 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,275 Joined: 24-September 03 From: Benson, AZ Member No.: 1,191 Region Association: Southwest Region |
I second solex!
| zeezee |
Apr 20 2009, 02:03 PM
Will do - Thanks.
Searching for "anneal" found some good threads for this that didn't turn up in my other "exhaust" oriented searches. - http://www.914world.com/bbs2/index.php?showtopic=82732 - http://www.ratwell.com/technical/Exhaust.html Sorry for the repetitive post. |
| Cap'n Krusty |
Apr 20 2009, 02:16 PM
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California |
If you're gonna file the pipes, you MUST file them together, not one port at a time. The Cap'n
Lo-Fi Version | Time is now: 29th April 2026 - 08:00 PM |
