its a gas, hood gas fillers |
firstknight13 |
May 9 2009, 07:19 PM
Senior Member Group: Members Posts: 652 Joined: 25-March 05 From: manchester,ct. Member No.: 3,817 |
(IMG:style_emoticons/default/biggrin.gif) ok so at hershey this car had a great gas door..it looks factory issue..dont know who's it is...lets see yours or the gas filler mod.....here is that car.....ray (IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/popcorn[1].gif)
Attached image(s) |
VaccaRabite |
May 9 2009, 07:33 PM
En Garde! Group: Admin Posts: 13,465 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
That one is not impossible to do if you have the tools to roll the metal over on the hood.
I have been thinking about doing this mod, but not the nice flush door like this one. I don't have a good roller to bend the metal over. Zach |
firstknight13 |
May 9 2009, 08:38 PM
i used to like the one on my 68 charger on the back quarter pop up
effutuo101 |
May 9 2009, 09:26 PM
Advanced Member Group: Members Posts: 2,735 Joined: 10-April 05 From: Lemon Grove Member No.: 3,914 Region Association: Southern California |
It does look like a 911 filler lid. maybe he cut the whole piece out and welded it in?
ChicagoPete |
May 10 2009, 12:10 PM
Member Group: Members Posts: 227 Joined: 10-January 05 From: Lake Forest,IL Member No.: 3,427 |
I am kind of partial to the ones on the Monte Carlo 914/6GT's. They seem to be held in place with a piece of foam that cinches into the hole? I was also thinking maybe a magnet that attaches to the filler cap, but that would weigh pretty much for use on a race car?
See more close up pictures at Armando's site: http://www.pbase.com/9146gt/image/54417623 http://www.pbase.com/9146gt/image/54417624 Peter Attached image(s) |
charliew |
May 10 2009, 12:43 PM
Advanced Member Group: Members Posts: 2,363 Joined: 31-July 07 From: Crawford, TX. Member No.: 7,958 |
The easiest way is to just cut it out of the donor panel and have someone tig it back in. You should be able to do it with almost no primer filler. If the welder thinks he can't butt weld it then do a little 1/8 lap and grind the remaining very small piece of lap off on the inside for no lap.
If it's a fiberglass hood a fiero filler door could be glassed in place, It's smc or pressed glass construction if I remember correctly. |
Lo-Fi Version | Time is now: 8th June 2024 - 03:40 PM |
