dbgriffith75 |
TheGrif ![]() ![]() ![]() Group: Members Posts: 509 Joined: 25-July 07 From: Iowa, USA Member No.: 7,945 Region Association: Upper MidWest ![]() |
I don't have anything in particular I'll need to wet sand soon, but I got to thinking about this today and was just wondering.
I've known some people to spray a given area with a hose, then sand. I've known some to wipe down the area with a wet rag, then sand. And one guy I know dips the sandpaper in water, then sands. My personal preference is to wipe down the area with a wet rag, then sand. Just wondering how other guys do it and what could be considered the "best method." (IMG:style_emoticons/default/beerchug.gif) |
PanelBilly |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,904 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest ![]() ![]() |
Soak paper in clean warm water for 10-15 minutes. Get a spray bottle and spray with one hand while you sand with the other.
biosurfer1 |
Teener fo Life! ![]() ![]() ![]() ![]() Group: Members Posts: 3,020 Joined: 3-August 03 From: Roseville, CA Member No.: 977 Region Association: Northern California ![]() |
Do NOT use your hand to apply the sandpaper, get a dense foam block.
sww914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,439 Joined: 4-June 06 Member No.: 6,146 Region Association: None ![]() |
If it's outside and it's warm I'll use a hose. If it's inside and I don't want a river running through the shop I use a bucket and a rag. If it's just a couple little spots I just dip the paper in a bucket here & there. You can use your hand if you're careful about not making high & low stripes with your fingers, if there's any doubt use a foam block. I always sand the bodylines, edges, and depressions first and then do the flats. That will smooth out any ridges that you made while concentrating on the little surface features.
76-914 |
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,737 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California ![]() ![]() |
From a guy who decided to paint his own plane and had to wet sand the entire clear coat job, take it from me. I like to keep a bucket of water with a few drops of dish soap, a hose for fresh water and pads. Depending on the surface you will need firm and soft backer pads. Keep your paper in the bucket when not using it. They'll keep for days in water. BTW the soap is a lubricant. Remember your actually cutting and the soap helps lubricate. (glycerine?) Whatever your sanding/polishing, you will need to take it up in graduated steps. Your wet/dry grit commonly runs in 800 - 2000 range. Jobber auto paint stores usually have all of this stuff and yes they will sell to you.
charliew |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,363 Joined: 31-July 07 From: Crawford, TX. Member No.: 7,958 ![]() |
All the above. The idea is to keep the paint from building up on the paper and scratching the surface. The fresher the paint the easier it will happen. You can feel it when it happens and the scratch is a mess to get out. You can never have too much water but you can also use less if you pay attention. I never use my bare fingers on any surface that is flat. Your fingers will never make a surface flat, I only use my fingers on edges. I usually only go in the same direction about 5 strokes, I go in circular, 45, 90 and 90 to that strokes. I use a bucket for small areas and a old bath towel to wipe up to check my progress. I usually use a stikit 3m yellow foam pad that is shaped like your palm on the top. I use it either direction though. I think it's a 3m product but it's been around a long time and lasts a ling time. I also use several different size dense rubber pads. If I'm doing tight inside curves I use a curved pad. I've been wetsanding for almost 50 years and my sanding muscles never tireout but this year my shoulder has started poping but it doesn't hurt or get sore. A lot of the pros are using a dry sanding system that has as high as a 3000 grit. it costs about 300.00 just to get started with it but they say a package of pads lasts a long time. I have some pretty expensive paint tools but that won't be one I think I will need.
effutuo101 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,736 Joined: 10-April 05 From: Lemon Grove Member No.: 3,914 Region Association: Southern California ![]() |
good advice. The only thing I have done different is to have a sponge that I dip in the water and keep close to where I am working to add water to the sanding. The spray bottle seems like a much cleaner idea.
dw914er |
Planning Cities ![]() ![]() ![]() ![]() Group: Members Posts: 2,365 Joined: 1-March 08 From: Yucaipa, CA Member No.: 8,763 Region Association: Southern California ![]() |
If it's outside and it's warm I'll use a hose. If it's inside and I don't want a river running through the shop I use a bucket and a rag. If it's just a couple little spots I just dip the paper in a bucket here & there. You can use your hand if you're careful about not making high & low stripes with your fingers, if there's any doubt use a foam block. I always sand the bodylines, edges, and depressions first and then do the flats. That will smooth out any ridges that you made while concentrating on the little surface features. (IMG:style_emoticons/default/agree.gif) (he taught me btw, and I used a foam block because it just made it alot easier since I was/am a n00b) |
TeenerTim |
Senior Member ![]() ![]() ![]() Group: Members Posts: 597 Joined: 22-October 07 From: Norfolk,VA Member No.: 8,253 Region Association: MidAtlantic Region ![]() |
I do it in the rain. A nice steady summer rain is best. Put on your swim suit, turn up the tunes, and get busy. The work goes very quickly. Now that I'm thinking about it you could turn on the lawn sprinklers... (IMG:style_emoticons/default/idea.gif)
Jeffs9146 |
Ski Bum ![]() ![]() ![]() ![]() Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 ![]() |
A friend of mine spent the summer when we were younger wet sanding a bug with a block and lots of beer! We had a left over keg with only a pump so it was going to go bad. He filled up his cup and drank a sip each time he dumped a sip!! Then rinsed the car with water when he was done.
His girlfriend ended up beating the paint with a spiked shoe and it didn't even chip it!! (IMG:style_emoticons/default/beerchug.gif) |
7TPorsh |
7T Porsh ![]() ![]() ![]() ![]() Group: Members Posts: 2,691 Joined: 27-March 06 From: Glendale Ca Member No.: 5,782 Region Association: Southern California ![]() ![]() |
Never sand in circles!!! Cross hatch in an X pattern and move side to side. Watch the edges.
Phoenix-MN |
Senior Member ![]() ![]() ![]() Group: Members Posts: 927 Joined: 23-January 04 From: ST. Bonifacius,MN Member No.: 1,590 ![]() |
(IMG:style_emoticons/default/agree.gif) with all of the above and add this:
Start color sanding with 1000, after a little sanding completely dry off the area, the orange peal low spots will still shine and the high spots will be dulled. When there is just a liittle shine left switch to 1500 and repeat until almost all of the shine is gone. Then switch to 2000 and finish the job. After final machine buffing it will be smooth as a babys butt. Paul |
jmill |
Green Hornet ![]() ![]() ![]() ![]() Group: Members Posts: 2,449 Joined: 9-May 08 From: Racine, Wisconsin Member No.: 9,038 Region Association: Upper MidWest ![]() |
Use 3M paper. I've never had a problem with it. Soak it first.
As far as water I like to rig up my own water system. Buy some 1/2 white pvc pipe. Cut a piece about 3' long and drill 1/8 holes in it down the pipe about an inch apart, all in a line. Glue a cap on one end and a hose fitting to the other. Not the threaded one. Get the fitting that plugs into the inside of the hose. That way there's no metal to scratch the paint. Get a couple of suction cups and attach them to the pvc pipe. You now can place the pvc sprinkler anywhere on your car and have constant fresh water. You can buy a setup like this but why when you can make it for less than $10. |
charliew |
I really don't use that much water you just need to keep the residue flushed out from under the paper. A squirt bottle is all I need or a sponge. Also not much pressure but keep the pad flat.
Porsche Rescue |
Saving and Enjoying Old Porsches ![]() ![]() ![]() ![]() Group: Members Posts: 2,978 Joined: 31-December 02 From: Bend, Oregon Member No.: 64 Region Association: None ![]() |
Just did some wet sanding yesterday after touching up some scratches by hand. You MUST use a sanding block. I like the 3M rubber block that takes a 1/4 sheet of paper. I used a squirt bottle with a few drops of liquid dish soap. Squirt/sand/dry with a rag and look at my work...repeat. The advice above about looking at the orange peel is important. I used 600 (very carefully), then 1000, then 1500, then buff.
I have used a bucket of water to dip sanding block in (indoors) and hose (outdoors) and I think the spray bottle is best. Enough water, easy to control, little mess, and it keeps the paper cleaner than the other methods. I wipe the paper with the rag at the same time I wipe the car. |
Lo-Fi Version | Time is now: 11th July 2025 - 05:26 AM |
