| 2-OH! |
Mar 1 2004, 02:34 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 552 Joined: 17-October 03 From: Santa Clarita, Kalifornication Member No.: 1,253 |
Hanyes manual says to set the clearance between the Reverse Idler and the sliding 1st shift gear to 1mm. The only problem is that the shaft for the Reverse Idler gear is roll pinned inside the rear cover so it's not possible to measure the distance, with the case on or without removing the pin...
Must be another way...Need some advice... 2-OH! |
| Bleyseng |
Mar 1 2004, 08:05 PM
Aircooled Baby! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,037 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
I used a deep dish socket that was the same diameter as the shaft to locate the rev gear with all the little pieces and then measure the adjustment.
Geoff |
Lo-Fi Version | Time is now: 1st May 2026 - 05:20 AM |
