Which wires go where?, RPM Gauge...only 2 wires? |
jcambo7 |
May 18 2009, 08:04 PM
Senior Member Group: Members Posts: 1,664 Joined: 24-December 08 From: Graham, WA Member No.: 9,867 Region Association: Pacific Northwest |
So I am finally trying to figure out why my rpm gauge doesn't work and I discover I can only find two wires...which makes no sense to me because their are 4 places on the back for wires. So I am just wondering if anyone has this gauge in their 914 and if they might know the answer to my wire predicament?
Here is the front Here is the back |
Racer |
May 18 2009, 08:09 PM
Senior Member Group: Members Posts: 787 Joined: 25-August 03 From: Northern Virginia Member No.: 1,073 Region Association: MidAtlantic Region |
Unique guage. I've never seen a tach/fuel tank combo before.
jcambo7 |
May 18 2009, 08:21 PM
rudedude |
May 18 2009, 08:25 PM
Senior Member Group: Members Posts: 511 Joined: 1-January 05 From: minneapolis, mn Member No.: 3,387 Region Association: Upper MidWest |
With a date stamp of 3-79?
Early 911's tach connections were +12v,+6v,trigger wire,and ground. Look closer on the plastic. good luck. |
detoxcowboy |
May 18 2009, 08:29 PM
Senior Member Group: Members Posts: 1,294 Joined: 30-January 08 Member No.: 8,642 Region Association: Africa |
jcambo7 |
May 18 2009, 08:48 PM
Ok. The writing on the plastic reads this left to right: +12 TD G -...these writings still don't help me in the fact that I only have two wires coming from the dashboard.
Larry.Hubby |
May 18 2009, 09:52 PM
Member who doesn't post much, but has a long time in 914s Group: Members Posts: 186 Joined: 24-November 04 From: Palo Alto, CA Member No.: 3,172 Region Association: Northern California |
I have a tach just like that in my car. It's a tach from a 930, and the small gauge at the bottom was originally a boost gauge that read either 0-1.5 bar (1977 only) or 0-1 bar (1978 and later). Someone has had North Hollywood Speedometer, or someone with similar skills, re-do the face, and perhaps the movement, of the small gauge to turn it into a gas gauge. The way to hook it up is with the red/white wire going to "+12" (the connection on the original 914 tach that this wire goes to would have been labeled "15"), and with the black/red wire going to the "TD" terminal (on the 914 tach, this would have connected to a terminal labeled "1"). The "G" terminal goes to the small gas gauge movement, and the other connection is a ground. If you want to use the small gas gauge, the green wire that used to go to the gas gauge in the combination instrument should be hooked to the "G" terminal.
Lo-Fi Version | Time is now: 8th June 2024 - 06:08 PM |
