can you identify this part? |
craig3x |
Jun 10 2009, 05:28 PM
Member Group: Members Posts: 106 Joined: 18-April 09 From: Sacramento Member No.: 10,275 Region Association: None |
going through a box of parts that came with my car, and came across this. No idea what it is for. Do you?
Phoenix-MN |
Jun 10 2009, 05:31 PM
Senior Member Group: Members Posts: 927 Joined: 23-January 04 From: ST. Bonifacius,MN Member No.: 1,590 |
Bushing for a side shifter transmission linkage
craig3x |
Jun 10 2009, 05:35 PM
g911 |
Member Group: Members Posts: 222 Joined: 13-January 06 From: Not Tellin' Member No.: 5,413 Region Association: None |
I truly have no clue, the first thing to come into my pea sized brain was a brass pedal cluster bushing replacement for the nylonish original.
Wilhelm |
Jun 10 2009, 05:43 PM
Member Group: Members Posts: 408 Joined: 7-September 07 From: Hooterville, OR Member No.: 8,088 Region Association: None |
Right here: That is if it has a 15mm bore. If its smaller I don't know.
craig3x |
Jun 10 2009, 05:46 PM
cool. I will go check that out. Thanks
craig3x |
Jun 10 2009, 06:08 PM
yep, fits like a glove, but i cant get the goddam ring/clip on it without the proper pliers
dbgriffith75 |
Jun 10 2009, 08:41 PM
TheGrif Group: Members Posts: 509 Joined: 25-July 07 From: Iowa, USA Member No.: 7,945 Region Association: Upper MidWest |
yep, fits like a glove, but i cant get the goddam ring/clip on it without the proper pliers If you have a pair of needle nose pliers that aren't too sentimental, and a bench grinder or file, the tips can be ground down to act as retainer ring pliers. I've done this with a couple of different pairs myself- it can be kind of a pain but it gets the job done. |
Derek Seymour |
Jun 10 2009, 08:45 PM
Member Group: Members Posts: 394 Joined: 10-March 09 From: Yucaipa Member No.: 10,151 Region Association: Southern California |
get one of these.. they are handy
(IMG:http://www.restockit.com/images/Product/medium/575-FA-469.jpg) |
Wilhelm |
Jun 10 2009, 11:14 PM
I like different sized snapring pliers rather than the ones above. I am always loosing all the little parts. These are cheap enuf and work well enuf:
Snap ring pliers |
craig3x |
Jun 10 2009, 11:48 PM
awesome. Thanks
Lo-Fi Version | Time is now: 11th June 2024 - 10:36 AM |
