For sale, Porsche 914 car system |
mr1970914 |
Jun 10 2009, 07:57 PM
I'm new here ... Group: Members Posts: 0 Joined: 24-January 09 From: New York Member No.: 9,969 Region Association: North East States |
I have tried to do this a few times with little to no luck. For sale is the ultimate 914 car package. I have it to fit any version of 914. I have it for the guys with 4x6" speakers or 6x5" door speakers. The package consist of (1) Pyle high power cd player, (1) Pyle stealth under the seat subwoofer with built in amp, (1) pair of Pyle high pwer 4x6" speakers or 6x5" high power speakers. Below I have made a list of all the specs. If you have any questions please feel free to email me at raj3wheels@tmo.blackberry.net or raj3@mail.com . Because of the busy work days, I will try to get back to you as soon as I can. Thanks for looking, enjoy you day.
8" Slim Active Subwoofer Details 600 Watt Max 8'' Super Slim Active Subwoofer RCA Low Level Input High Level Input Green & Red LED Power Status Indicator Remote Level Control Phase Shift Switch: 0 or 180˚ Adjustable Input Sensitivity: 0.2V-3V 0 to +12dB variable Bass Boost (@45Hz) Low Pass Filter (50-150 Hz) Soft Delay Remote Turn-On Thermal Short and Overload Protection Circuits Fuse: 2 x 15A Max Power: 600 Watt RMS Power: Amplifier 85 Watt/ Slim Woofer 200 Watt Dimension: 14. 5'' x 9.5'' x 3'' Weight 10.5 Lbs subwoofer 4x6" 240 watt 3way Speakers Details One Pair 4'' x 6'' Three-Way Triaxial Speaker Systems Power Handling: 120 Watts Rms / 240 Watts Max Non-fatiguing Butyl Rubber Surround 1'' High Temperature ASV Voice Coil Standard 4'' X 6'' Size Fits Oem Locations Blue Poly Injection Cone 20 Oz Magnet Structure 1'' Neodymium Film Dome Midrange 3/4'' Piezo Tweeter Impedance: 4 Ohm Sensitivity: 89 dB Frequency Response: 95Hz - 20Khz Includes Grills, Wires And Mounting Hardware Mounting Depth: 1.75'' 6x5" 360 watt 3way speakers Details One Pair 6.5'' Three-Way Triaxial Speaker Systems Power Handling: 180 Watts Rms / 360 Watts Max Non-fatiguing Butyl Rubber Surround 1'' High Temperature ASV Voice Coil Standard 6.5'' Size Fits OEM Locations Blue Poly Injection Cone 20 oz Magnet Structure 1'' Neodymium Film Dome Midrange 3/4'' Piezo Tweeter Impedance: 4 Ohm Sensitivity: 89 Db Frequency Response: 90Hz - 20Khz Includes Grills, Wires And Mounting Hardware Mounting Depth: 1.9'' Auto loading cd/mp3 player Details AM/FM 2 Band Radio Auto Loading Car CD/MP3 Player Multi-Color LCD Digital Display with Dancing Spectrum AUX-IN on Front for Portable MP3 Players ID3 Tag Function (Song/Singer Name Display) Detachable Front Panel Rotary Tuning Control ESP (Electric Shock Protection) Balance/Treble/Bass/Fader Control Preset EQ (POP/Rock/Classic/Flat) 10 Songs Skip Up/Down Clock Function Band Function Mute Function Repeat Function Electronic Volume Control 4-Channel High Power Output RCA Line Out 200 Watts Total Output (4 X 50 Watts) Free 3 button car alarm with any package purchase. Details Two 3-button Transmitters w/Labeled Buttons Built-in Relay for Parking Lights LED Status Indicator Emergency Override Switch Door Lock Outputs Electronic Dual Stage Shock Sensor 120dB 6-tone Siren 2 Auxiliary Outputs Dome Light Output Panic Mode Anti-Carjack Mode Valet Mode Tamper Alert Automatic Bypass for Defective Zones Programmable Manual/Passive Arming Programmable Passive Door Locking Programmable Ignition Controlled Lock/Unlock Programmable Chirp Bypass Temporary Chirp Mute Non-volatile Memory I will even throw in a pair of tri-mount tweeters. The package cost is $375.50 with shipping to any of the 50 states. The active subwoofer is $310 alone. Thanks and enjoy your day. You will also get a UPS tracking number with every order. Once again thanks and enjoy your day. Attached image(s) |
RJMII |
Jul 5 2009, 11:24 AM
Jim McIntosh Group: Members Posts: 3,125 Joined: 11-September 07 From: Sandy, Utah Member No.: 8,112 Region Association: None |
You obviously don't own a 914... Under the seat amp?? (IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/av-943.gif)
Gint |
Jul 5 2009, 02:15 PM
Mike Ginter Group: Admin Posts: 16,082 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
I'll move this ad to the proper classified section.
Lo-Fi Version | Time is now: 31st May 2024 - 11:35 PM |
