MPS tests, I have one on the shelf |
Project 6 |
Jun 16 2009, 04:36 PM
large member Group: Members Posts: 359 Joined: 30-December 02 From: Utah Member No.: 51 Region Association: None |
How does one bench test a 2.0 MPS?
r_towle |
Jun 16 2009, 05:30 PM
Custom Member Group: Members Posts: 24,586 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
to see if its worth anything? I know you will never use it...its Djet FI...
You need to pull 15 on a vacuum guage for 30 minutes. To much and you will break it. Basically, it needs to hold a vacuum. If you can suck on it and your tongue sticks (like when we were kids) then its fine. Rich |
Cap'n Krusty |
Jun 16 2009, 05:34 PM
r_towle |
Jun 16 2009, 05:35 PM
I figured someone would pick up on that after I wrote it...
We have never met...its a virtual thing. R |
SLITS |
Jun 16 2009, 06:33 PM
Pull 20" of vacuum on it. Should not leak down past 15" in 5 minutes.
Check the ohms between the 4 pins ---- 90 ohms between the outside pins and 350 ohms between the inside pins (or it could be the other way around, I'm to lazy to check). Check each pin to ground ... should not show continuity. And if you can pull 20" of vacuum by sucking, I would like to talk to you. See PBanders website for all the information. And Mikey, send it to me .... I'll test it and maybe we can work a trade. |
914Sixer |
Jun 16 2009, 06:34 PM
914 Guru Group: Members Posts: 8,900 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Electrical part rarely fails. The copper diaphram is the problem. The design of it lets it break in a circle.
914werke |
Jun 16 2009, 07:15 PM
"I got blisters on me fingers" Group: Members Posts: 10,124 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Pull 20" of vacuum on it. Should not leak down past 15" in 5 minutes. ...And if you can pull 20" of vacuum by sucking, I would like to talk to you. (IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/av-943.gif) |
Project 6 |
Jun 17 2009, 12:18 PM
http://www.enercongroup.com/conversion_factors.htm
Per the above conversion calculation chart, 20 IWC to PSI is .7 pounds per square inch. Pretty weak Blow Job. That pressure wouldn't even inflat Slits' blow up doll. |
Lo-Fi Version | Time is now: 6th June 2024 - 05:41 AM |
