what are these wires for?, left overs from the relay board |
RJMII |
Jun 23 2009, 12:17 AM
Jim McIntosh Group: Members Posts: 3,125 Joined: 11-September 07 From: Sandy, Utah Member No.: 8,112 Region Association: None |
The diagrams I was looking at were slightly vague about where these wires go...
they used to go to my relay board. any help would be greatly appreciated. Attached thumbnail(s) |
astronomerdave |
Jun 23 2009, 02:44 AM
Member Group: Members Posts: 69 Joined: 26-January 09 From: Los Angeles, CA Member No.: 9,979 Region Association: Southern California |
I recently disassembled mine; here's what I have in my notes from my 1972/4. Looking at the plug, where the (O) is the locating pin, no wire, and the O designates the pins with wires:
CODE 2 O (O) O 1 4 O O 3 6 O O 5 8 O O 7 10 O O 9 12 O O 11 14 O O 13 Then I have this for the colors by above pin number: 1: yellow 2: blue, gen 3: grey/pur, back-up lights 4: grey/pur, back-up lights 5: green/brown, oil pressure 6: (empty) 7: black/pur, tach 8: black, keyed +12 ign 9: green/white 10: brown 11: (empty) 12: red 13: black/red 14: red (3,4,5,7,8 were the only wires I was looking for, so that's why they are the only ones above with a labeled purpose) |
RJMII |
Jun 23 2009, 09:42 AM
Dave, that helps some. thank you. (what were you doing to your car? I think you picked out most of the same wires that I did?)
there are two for the back up lights? Do I wire these two straight to the transimssion? |
astronomerdave |
Jun 23 2009, 12:11 PM
Dave, that helps some. thank you. (what were you doing to your car? I removed the engine and installed an electric motor: click here for electric car link, and 3,4,5,7,8 were the only wires I needed off the relay board. there are two for the back up lights? Do I wire these two straight to the transimssion? Well, as I removed the relay board, those two are now connected to my reverse light switch on the trans instead of running through the relay board. Are you trying to re-assemble the relay board, or something more like what I did? |
SirAndy |
Jun 23 2009, 12:45 PM
Resident German Group: Admin Posts: 41,673 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
The diagrams I was looking at were slightly vague about where these wires go... Really? And what year is your car? 70/71/some 72: Attached thumbnail(s) |
SirAndy |
some 72, 73 and newer:
SirAndy |
Jun 23 2009, 12:57 PM
Blue, Pin 2: Goes from your alternator to the alternator light in your gauge Green/Red, Pin 5: Goes from your Oil Pressure switch to the oil idiot light in your gauge Green/White, Pin 9: Comes from the heater fan switch, goes to relay 55 Green, Pin 11: Comes from relay 55 and goes to the heater fan I can't really tell the other wire colors. Your picture is too fuzzy ... (IMG:style_emoticons/default/shades.gif) Andy |
SirAndy |
Jun 23 2009, 12:58 PM
Racer |
Jun 23 2009, 02:54 PM
Senior Member Group: Members Posts: 787 Joined: 25-August 03 From: Northern Virginia Member No.: 1,073 Region Association: MidAtlantic Region |
Mine were connected to the Flux Capacitor.. which is what makes time travel possible.
RJMII |
Jun 23 2009, 10:12 PM
Ahh... Thank you Andy! Somehow I managed to not DL the legend for the wiring diagram.
I'll try to take a less fuzzy picture for you. and the car is a 76. |
Lo-Fi Version | Time is now: 4th June 2024 - 10:41 PM |
