how to check injector spray? |
jimkelly |
Jun 28 2009, 08:01 AM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
do i pull one injector and put it into a baby food jar and then run the car for 5 minutes - repeat this on each injector?
jim |
SLITS |
Jun 28 2009, 08:13 AM
"This Utah shit is HARSH!" Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
Put all four in baby food jars .... crank engine for 30 seconds*** ... you are looking for:
Spray characteristics ... nice conical mist Volume of each Disconnect coil so you don't produce any spark. *** To avoid overheating starter ... 30 seconds max ... then let it cool. |
jimkelly |
Jun 28 2009, 08:31 AM
thanks - jim
on D jet - do 1 and 3 fire at same time - same for 2 and 4 ?? or is this only with L jet? |
pcar916 |
Is that a Lola? Group: Members Posts: 1,523 Joined: 2-June 05 From: Little Rock, AR Member No.: 4,188 Region Association: None |
You can make a grid and measure the pattern of each injector too. Flow rate is easy. If it hasn't been done before, the o-rings should be replaced too.
I had a problem after a motor had been sitting for some time. Bosch makes an injector cleaning machine that measures everything. Injector places have them. But I got instant results by soaking the injector tips in fuel and injector cleaner, and hooking the injectors up to a power source on my bench to get the wires moving. Got them cleaned professionally after the car ran properly... just to be sure I had a baseline for each. |
r_towle |
Jun 28 2009, 09:16 AM
Custom Member Group: Members Posts: 24,585 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
You should pull the spark plugs to allow the motor to turn easier.
Rich |
jimkelly |
Jun 28 2009, 09:34 AM
SLITS |
Jun 28 2009, 10:08 AM
Lo-Fi Version | Time is now: 3rd June 2024 - 09:46 AM |
