| pcar916 |
Jul 6 2009, 08:21 AM
Is that a Lola? ![]() ![]() ![]() Group: Members Posts: 1,524 Joined: 2-June 05 From: Little Rock, AR Member No.: 4,188 Region Association: None
I'm adding a cooler and pump to my transmission. These two pumps are similar in specification and both companies have been around a long time.
Tilton: http://www.summitracing.com/parts/TIL-40-524/ Mocal: http://www.racerpartswholesale.com/product...ial_Cooler_Pump I know several of you run Jabsco Water Puppy pumps, but I see no advantage to it over the Mocal or Tilton. Anyone out there with experience as to whether one is more reliable than the other? |
| ArtechnikA |
Jul 6 2009, 09:00 AM
rich herzog ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None |
I'm adding a cooler and pump to my transmission. These two pumps are similar in specification and both companies have been around a long time. Anyone out there with experience as to whether one is more reliable than the other? I've never used either but I do read a lot of spec sheets ;-) Ordinarily my personal preference would be for the Tilton over the Mocal, for no reasons I can readily quantify. but a 265°F max temp limit for the Tilton would be scary, I think, for a track car (and if it's not a track car, why would you need a cooler?). The Mocal does claim 300°F max temp. I've bought from both vendors with no issues so that's not a differentiating help either... |
| pcar916 |
Jul 6 2009, 09:11 AM
QUOTE but a 265°F max temp limit for the Tilton would be scary, I think, for a track car (and if it's not a track car, why would you need a cooler?). The Mocal does claim 300°F max temp. I haven't tested the transaxle fluid temps in my car yet, but today I'll point an infrared thermometer at it after several spirited runs up a local steep and twisty grade. just to get a feel, but 265°F degree transmission fluid scares me no matter what. What track temps are expected with a clutch type LSD? |
| ArtechnikA |
Jul 6 2009, 09:17 AM
265°F degree transmission fluid scares me no matter what. What track temps are expected with a clutch type LSD? I agree, which is why I think it'd really suck if the pump died at 266... If you figure a conservative 10% power loss in the drivetrain, it means if you 've got a 200HP engine, the transmission is making as much heat as a 20HP motor... Also figure the transmission is aft of the engine and over the exhaust. I believe (but do not have the instrumentation to prove (yet) that mid-200's temps are common and 300's are possible. |
| pcar916 |
Jul 6 2009, 10:07 AM
265°F degree transmission fluid scares me no matter what. What track temps are expected with a clutch type LSD? I agree, which is why I think it'd really suck if the pump died at 266... If you figure a conservative 10% power loss in the drivetrain, it means if you've got a 200HP engine, the transmission is making as much heat as a 20HP motor... Also figure the transmission is aft of the engine and over the exhaust. I believe (but do not have the instrumentation to prove (yet) that mid-200's temps are common and 300's are possible. Well, my 3.6L gives me 210hp to the rear wheels, not sure about brake hp numbers. But I know the LSD produces a lot more heat than either an open or TBD if I'm in the twisties for any length of time or on the track. I've always wondered how much the exhausts contribute. They are well to the side and probably not a huge factor while moving, but as this is a street/track car, it does see some traffic lights. I'll be installing a temperature sensor because... it's obviously the right thing to do. It's definitely an issue in the Southern USA. |
| puff adder |
Jul 6 2009, 06:47 PM
Member ![]() ![]() Group: Members Posts: 77 Joined: 9-December 08 From: northern california Member No.: 9,827 Region Association: None |
I've read about cooling systems with spray bars inside the tranny, and others that tap into the side with spray emitters.
Can a cooling system be installed on a 915 box without removing it from the car? |
| ArtechnikA |
Jul 6 2009, 07:25 PM
I've read about cooling systems with spray bars inside the tranny, and others that tap into the side with spray emitters. Can a cooling system be installed on a 915 box without removing it from the car? transmission removal is trivial, unlike the engine, which is merely easy. Undo the shift linkage, unbolt the halfshafts, ta da. (Support the engine...) Deal with the speedo sender, whether it be electric or mechanical cable... Pull off the tail cone, remove the gear stacks as a unit. do what you need to with no issues about whether or not drilling chips got inside. (Almost) anything _can_ be done, but it's so easy to pull the box and do this with relative ease on the bench, why make things harder on yourself than you need to ? |
| puff adder |
Jul 6 2009, 08:39 PM
Thanks for the info.
I guess I'm more interested in whether it can be done without taking the box apart. Removing the box from the car is super easy on my car, but I have limited experience with the innards of transmissions. This is something I might do later on. I've been at the track a lot lately. It appears that after the boxes get hot (901 and 915) they get cranky. I see and hear the shifts at the beginning, and the end of 20 minute runs, and towards the end the drivers are shifting more methodically, whereas at the starts they are shifting quickly and easily. Conclusion is a cooler box is a happier box. I've read about cooling systems with spray bars inside the tranny, and others that tap into the side with spray emitters. Can a cooling system be installed on a 915 box without removing it from the car? transmission removal is trivial, unlike the engine, which is merely easy. Undo the shift linkage, unbolt the halfshafts, ta da. (Support the engine...) Deal with the speedo sender, whether it be electric or mechanical cable... Pull off the tail cone, remove the gear stacks as a unit. do what you need to with no issues about whether or not drilling chips got inside. (Almost) anything _can_ be done, but it's so easy to pull the box and do this with relative ease on the bench, why make things harder on yourself than you need to ? |
| pcar916 |
Jul 6 2009, 09:21 PM
You could do it if you ignored squirters on the gears, and perhaps used the drain and fill plugs for in and out of your fluid after the fluid was drained.
But with some finesse, you can take the transaxle out without taking the motor out. Then you can install brass/bronze bosses for your cooler system elsewhere on the case. If you decide to install squirters, don't make the mistake of pointing the oil flow into the mesh areas of the gears and R&P. That makes for huge forces pushing them apart as they try to squeeze the oil out from the mesh. |
| john rogers |
Jul 7 2009, 12:15 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,525 Joined: 4-March 03 From: Chula Vista CA Member No.: 391 |
I would recommend calling several shops that RACE vintage 911s and 914s with high revving engines and see what they use and recommend. I bought a complete setup from Jim Patrick in Phoenix as I didn't have a lot of time to run around and gather up all the bits and pieces. Several things to note:
- Yes you have to open the case so you can drill and tap for the nozzle over the ring and pinion as that is the heaviest loaded on a race box. As noted the limited slip also does generate a bunch of heat AND you do not want to have any chance of chips left in the case. - The direction of oil spray is immaterial as any excess will splash off the gears and not cause any type of hydraulic locking or such. Just make sure one goes on top of the R&P - You will need to add a closed vent run to your puke tank since you will be running an extra quart of trans oil (4 total now) to make up for the new plumbing, cooler, etc. - Add a switch so you can turn the pump on/off or leave it run after you shut off the engine when done with a race group. - Most 914s I have seen put the cooler in the floor of the rear trunk and vent air into it and out the botom. I added a small boat type axial fan to help out when it is really hot. - Use stainless braided lines for the suction and returns since they are in a position at the rear that gets a lot of abuse from road stuff. - Patrick sells a replacement plug for a temp gauge so you can see what the trans temp is doing, very handy to have. I had run a cooling system for 5 years since putting the six in the race car and never broke a gear box and the ones that Wayne Baker, Frank Beck and Jim Patrick all raced never experienced any failures as far as I know. |
| Downunderman |
Jul 7 2009, 12:48 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 852 Joined: 31-May 03 From: Sydney, Australia Member No.: 766 Region Association: Australia and New Zealand |
If you are running a 6 a sportomatic pump off the back of the camshaft works well.
| stownsen914 |
Jul 7 2009, 08:00 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 996 Joined: 3-October 06 From: Ossining, NY Member No.: 6,985 Region Association: None |
If you decide to install squirters, don't make the mistake of pointing the oil flow into the mesh areas of the gears and R&P. That makes for huge forces pushing them apart as they try to squeeze the oil out from the mesh. I have heard this elsewhere, and am interested knowing why it matters. If you look at a the oil level in a stock 901, the gears mesh very close to that point. It seems like the oil would be carried into the mesh area by the rotation of the gears. Why is it any worse to spray oil under modest pressure where the gears mesh? Scott |
| pcar916 |
Jul 7 2009, 09:09 AM
If you decide to install squirters, don't make the mistake of pointing the oil flow into the mesh areas of the gears and R&P. That makes for huge forces pushing them apart as they try to squeeze the oil out from the mesh. I have heard this elsewhere, and am interested knowing why it matters. If you look at a the oil level in a stock 901, the gears mesh very close to that point. It seems like the oil would be carried into the mesh area by the rotation of the gears. Why is it any worse to spray oil under modest pressure where the gears mesh? Scott The level is lowered during running since a lot of it is up in the gear train and on the top and sides. Most of the oil is spun off anyway and a thin film is all you want. If oil is forced into the mesh a lot more oil can't spin off fast enough, and can't compress either, so the gears are forced apart more than they were designed for. With the R&P, this means at the very least, that the carrier bearings are loaded more than they should be. The other gears would be the same, higher bearing loads. I don't know if it would be enough to break teeth, but it would certainly run hotter... and cool is good. At worst I suppose a mag case could be compromised. This might make a difference in an early 915 case with a 2-piece bearing plate and an un-reinforced side cover. I have two of those transaxles. No racer would use them use them without the updated parts, but someone else might. |
| pcar916 |
Jul 7 2009, 09:38 AM
Downunderman...
- I have a power take-off on the back of this 3.6L where the power steering pump used to be. And I still have the pump and belt as well. That said I'm not sure what the impact to the cam and chain would be with the added load. My flywheel is only 6.75# and I'm running an early clutch/pressure plate so it's all very light. I use the throttle to minimize the whipping of accel/decel but adding that load would make me nervous about snapping that cam in half. If I wanted to go mechanical, I could mount a pulley on the inside transaxle flange at the cv and run a mechanical pump from that. If it doesn't run while I'm sitting still, so what? John... - What operating temps do you see? - Excellent points that I'll follow on the install. I was going to put one squirter in the side cover pointed at the bottom of the ring. On the top would be easier and I wouldn't have to remove plumbing when the side cover comes off. I like that. - As for the pump it appears that some racers use the Weldon 9200A. http://www.weldonracing.com/product/54-7/9...e_Oil_Pump.html Weldon is proud of it but it looks very good. |
| john rogers |
Jul 7 2009, 10:26 AM
If you hook up the plumbing system you might be surprised and how little the actual flow is with any of the pumps. On the transmissions I setup and all the ones I have seen the outlets were on top of both the gear stack and also the R&P and essentially the oil just ran down on everything. The idea is two fold, first to get the oil cooled off and second to get as much as possible onto the gears to they will then cool off.
The highest temps I ever saw were at a race in Tecate MX when it was 96 degrees during the race and the trans got to about 275 or so. The temps were high due to the constant shifting and the tight corners making the GT limited slip work really hard. At the CA speedway when temps were 104 the temp only got to 210 due to the long run time on the NASCAR portion of the track. Less shifts mean less heat build up I imagine. |
| pcar916 |
Jul 7 2009, 11:03 AM
If you hook up the plumbing system you might be surprised and how little the actual flow is with any of the pumps. On the transmissions I setup and all the ones I have seen the outlets were on top of both the gear stack and also the R&P and essentially the oil just ran down on everything. The idea is two fold, first to get the oil cooled off and second to get as much as possible onto the gears to they will then cool off. The highest temps I ever saw were at a race in Tecate MX when it was 96 degrees during the race and the trans got to about 275 or so. The temps were high due to the constant shifting and the tight corners making the GT limited slip work really hard. At the CA speedway when temps were 104 the temp only got to 210 due to the long run time on the NASCAR portion of the track. Less shifts mean less heat build up I imagine. Excellent. I'll run the entire pump/manifold and squirters on a bench prototype first just to see what it will produce with the oil both cold, and at high temperatures. I have lots of -6 and -8 stuff around the shop so I'll just use what's here. As for flow, I'd rather have a lot of it at low pressure, but want the oil in the cooler long enough to maximize heat transfer. Wish we could add some PCB's (kidding a little bit). I've been told that both Swepco dino oil, and the Lubrication Engineer's synthetic are good lubes to use with this GT LSD that I've just put into this box. I'm leaning toward the LE for the EP rating and the longevity but I have to buy 5 gal. at a time. Guess I'll be using it for a while. I talked to some local guys who follows NASCAR obsessively and the ~210F seems to be normal operating temp for those cars as well. |
| john rogers |
Jul 7 2009, 11:34 AM
I guess I am getting old as I forgot to mention to make sure to install a filter in the pump suction. I forget the brand I used but it was one of the plate type and I would open it a couple of times a year for checking of metal pieces. If the transmission distructs it will catch the pieces and prevent the additional pain of having to replace the pump.\
If you set things up right you can use the the pump to fill or empty the transmission which I did and it is much better than using the drain plug. |
| pcar916 |
Jul 7 2009, 03:44 PM
I guess I am getting old as I forgot to mention to make sure to install a filter in the pump suction. I forget the brand I used but it was one of the plate type and I would open it a couple of times a year for checking of metal pieces. If the transmission distructs it will catch the pieces and prevent the additional pain of having to replace the pump.\ If you set things up right you can use the the pump to fill or empty the transmission which I did and it is much better than using the drain plug. I figured on a Canton Mecca canister filter inline so it can be checked without draining, and will protect both pump and cooler. Pump to drain huh? This mod just keeps gettin' better by the minute. If installed as you suggested, the cooler will drain back into the transaxle every time the car is turned off unless there is enough tilt to keep the oil in the cooler, and/or an anti-siphoning valve is installed. I was going to position the cooling system to try and keep the stock fluid level in the box, even with the added capacity, just to perhaps avoid possible leaks. |
| jt914-6 |
Jul 7 2009, 05:14 PM
Driving & working on teeners 41 years ![]() ![]() ![]() Group: Members Posts: 1,787 Joined: 3-May 08 From: Bryant, Arkansas Member No.: 9,003 Region Association: South East States |
I've got a brass 1/2" female one way valve if you can use it....... (IMG:style_emoticons/default/shades.gif)
| Downunderman |
Jul 7 2009, 05:28 PM
I have been using the sporto pump for a couple of years now with no apparent adverse consequences; GE80 cams and VMax springs which have an open pressure of about 285 lbs. I think the pump has an internal pressure relief bypass from memory. I have also plumbed in a cartridge type filter to get rid of all the shiny bits and clutch material from the LSD which also has a pressure relief bypass in it. I am not using big revs though, about 7,200. No photos at the moment because i'm at work.
Lo-Fi Version | Time is now: 2nd April 2026 - 02:54 PM |
