Back-up Light Switch - HELP! |
vesnyder |
Jul 17 2009, 05:42 AM
Senior Member Group: Members Posts: 680 Joined: 14-April 05 From: Cleveland, OH Member No.: 3,933 |
OK - Just purchased a used back-up light from a fellow board member for the 901 tranny. I first tested the switch to make sure it works (tested the continuity when the inner button is engaged). I then tested the back up lights by touching the wires. But when I installed the switch the lights do not come on? I had a prior switch that worked - but now that I think of it it may have been on another tranny? Is there a chance that the mechanism inside the tranny that engages the switch is broken? Does the engaging mechanism inside the tranny need alignment? Thanks ahead of time for your help! |
914Sixer |
Jul 17 2009, 07:27 AM
914 Guru Group: Members Posts: 8,897 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Transmission switch is probably good . The pin is probably worn out making it to short to make contact.
Lo-Fi Version | Time is now: 1st June 2024 - 08:29 PM |
