| Heeltoe914 |
Jul 17 2009, 11:59 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,135 Joined: 31-January 06 From: Tujunga Calif, Member No.: 5,506 |
Setup is full simi tube car 1775 appox, 10 and 12 LSD Boxster brakes Combo of high speed tracks and AX. Driving.
Hi guys starting stage three of the upgrades to my Spyder racecar. I am planning to add Adjustable front and rear shocks. The front should not be such a big deal the shocks on the car now are made by a Company called Carrera Shocks. The front’s inserts are much shorter than a Carrera or SC size inserted shock. It’s about 10.5 inch long. The rears are short about 12.5 “. If you notice the rear shocks are inverted, I would like to find something that will mount with the shock bolt and damper location. What makes finding a replacement a challenge is that the stub that is welded onto my rear shocks is not commonly done and would have to be done before the shock is constructed. I would think that there are other ways of getting a inverted shock on a 914 using stock mounting locations. Advice or suggestion welcomed. Part two; Another question I have is if you have a track only racecar that ran as a high output four banger with a very good setup, than converted it to a 3.6 which adds some weight & HP what guess would you make on how much to go up on front and or rear spring rates??? I am thinking 50pds per corner just for the weight but I need to add in the hard acceleration and cornering as well. What has anyone here tried? Attached image(s)
| Randal |
Jul 17 2009, 01:01 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,446 Joined: 29-May 03 From: Los Altos, CA Member No.: 750 |
What are you going to be doing with the car? Driving on the street, autoxing, track days, hillclimbs or what? |
| PeeGreen 914 |
Jul 17 2009, 02:09 PM
Just when you think you're done...wait, there is more..lol ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,219 Joined: 21-September 06 From: Seattle, WA... actually Everett Member No.: 6,884 Region Association: Pacific Northwest
JRZs are the best you can get for the 914
| Heeltoe914 |
Jul 17 2009, 02:25 PM
Randel its a full out chop top race car.
| Randal |
Jul 17 2009, 04:06 PM
Randel its a full out chop top race car. OK, road racing then. (IMG:style_emoticons/default/beerchug.gif) I still think the best solution is to get your existing shocks revalved to match the weight of your car and venue. I'm probably to be going with Bilsteins when I make the move from the existing Koni's, but again revalved for the specific weight and venue I'm going to be running. Although I have yet to check to Koni to see if they can do the same re-valving. Oh, I'd vote for Ground Control shocks, as the best I've ever ran. They are just so much better than anything else I've driven it's hard to describe. |
| DanT |
Jul 17 2009, 06:12 PM
Going back to the Dark Side! ![]() ![]() ![]() ![]() Group: Members Posts: 4,300 Joined: 4-October 04 From: Auburn, CA Member No.: 2,880 Region Association: None |
Randal,
it is the EX-Bill Newlin hot rod with a 3.6L in it instead of the type IV Attached image(s)
| Randal |
Jul 17 2009, 07:20 PM
Randal, it is the EX-Bill Newlin hot rod with a 3.6L in it instead of the type IV That car was very nicely done. Always fun to watch and very fast. Watching that car run, with a big 4, was definitely influential on my decision to build one. Must be crazy with a 3.6 behind the driver. I still say that re-valving what you have or getting a major brand, like the billies, and doing the same is the most cost effective move. But if I found $4,000 sitting around I'd probably go straight to Ground Control. Those shocks simply work. It would be fun to run a shock test between the JRZ and the Ground Controls, but we need one of our engineering geniuses here to help us understand the data. |
| Heeltoe914 |
Jul 17 2009, 10:55 PM
Well Randell you think like I. I have tried to find the Company Carrera or any other company that can re-valve or just rebuild the shocks I have but thay are a sealed unit from what I am finding out. Can't be done. So Carrera out of business and no one to re-valve puts me here asking for help.
| Joe Ricard |
Jul 18 2009, 06:27 AM
CUMONIWANNARACEU ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 |
Well since it is a full out race car get full out race shocks.
I already answered this with my opinion on the other site. Didn't know ground control made a shock. I thought they used advance design bodies with thier spring adapters/adjusters. |
| Heeltoe914 |
Jul 19 2009, 12:20 AM
Thanks Joe I did some looking tonight on Ebay and this may be a option dod you have a part number and what dose your car weight? If you have a setup that already works I may look into it more.
Thanks for the info. |
| Joe Ricard |
Jul 19 2009, 05:52 AM
Aluminum large body threaded 7"shock. 147# series is what I use. The pound sign is the valving number rated from 1-10. if the is a - and another number it is a spit valve indicating rebound. Mine are double adjustable. which I hardly fuss with anymore as I think I have them dialed in pretty well. 6 compression and 7 rebound.
| Heeltoe914 |
Jul 19 2009, 10:32 AM
Aluminum large body threaded 7"shock. 147# series is what I use. The pound sign is the valving number rated from 1-10. if the is a - and another number it is a spit valve indicating rebound. Mine are double adjustable. which I hardly fuss with anymore as I think I have them dialed in pretty well. 6 compression and 7 rebound. So your 7 inch shock with a 10 inch spring??? I have a assortment of springs at 10 " so I will try to match a set that will allow me to still use the collection of springs I have. did you mount them inverted?? |
| Joe Ricard |
Jul 19 2009, 02:19 PM
yes inverted.
you will need a bracket to mount it to the shock tower but these can be picked up from any circle track shop. |
| bam914 |
Jul 22 2009, 08:09 PM
Member ![]() ![]() Group: Members Posts: 342 Joined: 23-November 03 From: Atlanta, Ga Member No.: 1,378 Region Association: None |
I have an extra set of Dynamic Suspension canister shocks that I want to sell. You can mount them either way. They are double adjustable. Fully extended they are 18 1/2" .
| Heeltoe914 |
Jul 22 2009, 09:44 PM
Thanks for the offer can you drop me a PM I think the problem will be the cansiter Fitting into the space I have to work with. PM price and any info you have Or Heeltoe914@aol.com
| Joe Ricard |
Jul 24 2009, 09:15 PM
Dang Blake that is nearly exactly how I mounted the lower eye of my shocks. And I never seen your set up before.
| bam914 |
Jul 24 2009, 09:23 PM
Those lower mounts were made by Carrera when they were still in business. Direct bolt in units.
| stewteral |
Sep 19 2009, 12:45 PM
Old Member ![]() ![]() Group: Members Posts: 384 Joined: 4-December 07 From: Camarillo, CA Member No.: 8,424 Region Association: Southern California |
Setup is full simi tube car 1775 appox, 10 and 12 LSD Boxster brakes Combo of high speed tracks and AX. Driving. Hi guys starting stage three of the upgrades to my Spyder racecar. I am planning to add Adjustable front and rear shocks. The front should not be such a big deal the shocks on the car now are made by a Company called Carrera Shocks. The front’s inserts are much shorter than a Carrera or SC size inserted shock. It’s about 10.5 inch long. The rears are short about 12.5 “. If you notice the rear shocks are inverted, I would like to find something that will mount with the shock bolt and damper location. What makes finding a replacement a challenge is that the stub that is welded onto my rear shocks is not commonly done and would have to be done before the shock is constructed. I would think that there are other ways of getting a inverted shock on a 914 using stock mounting locations. Advice or suggestion welcomed. Part two; Another question I have is if you have a track only racecar that ran as a high output four banger with a very good setup, than converted it to a 3.6 which adds some weight & HP what guess would you make on how much to go up on front and or rear spring rates??? I am thinking 50pds per corner just for the weight but I need to add in the hard acceleration and cornering as well. What has anyone here tried? Hi Heeltoe914, I love your car!! On my 914 V8 street/track toy, I'm running a pair of special-built Koni dual adjustables in the rear and they are working great. However, I've ONLY found rebound-adjustable Koni Sports shocks for the 911 Boge front struts. Do you know of any source for a DUAL-ADJUSTABLE cartridge shock for my 911 struts? Best, Terry |
| bam914 |
Sep 19 2009, 02:37 PM
Look up a Koni 8611 series. It is a double adjustable strut insert. I am using these on my 914 now. It fit the the 911 strut. You will need to shorten the strut housing and adapt the top of the strut. It has a 14mm thread there.
| Britain Smith |
Oct 16 2009, 02:58 PM
Nano Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,354 Joined: 27-February 03 From: Hillsboro, OR Member No.: 364 |
Blake, do you have a picture of the front assembly set-up? Those 8611 series are fairly cheap.
-Britain |
Lo-Fi Version | Time is now: 2nd April 2026 - 05:17 PM |
