Dman |
Member ![]() ![]() Group: Members Posts: 163 Joined: 18-February 03 From: Sacramento CA Member No.: 311 ![]() |
Give it to me straight guys how bad is this? (IMG:style_emoticons/default/unsure.gif)
Should I replace all of the panels or is there an alternatve? There is a small 3/8 hole in the top of the frame member but there is NO rust on the bottom side of the car (jack point/suspension mount). |
Dman |
Stupid me, here is the picture.
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,200 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
How much do you like this particular car? How much work have you put into it so far?
If you can weld, it is very saveable. Not a real huge deal. But if you can find a non-rusty donor car, it might wind up being easier to swap the good parts over. --DD |
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,257 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
naaa, that's good!
spray "Metal Ready" in the holes in the frame and on everything else. (yes, you can weld through Metal ready), then weld a plate over the mess. then put POR-15 on it. see here: (IMG:http://www.sirandy.com/pix/914/work/039.jpg) (IMG:http://www.sirandy.com/pix/914/07.30.2002/IMGP0266.jpg) (IMG:http://www.sirandy.com/pix/914/07.30.2002/IMGP0267.jpg) (IMG:http://www.sirandy.com/pix/914/07.30.2002/IMGP0286.jpg) |
airsix |
I have bees in my epiglotis ![]() ![]() ![]() ![]() Group: Members Posts: 2,196 Joined: 7-February 03 From: Kennewick Man (E. WA State) Member No.: 266 ![]() |
QUOTE(Dman @ Apr 2 2003, 10:29 AM) Give it to me straight guys how bad is this? :unsure: Should I replace all of the panels or is there an alternatve? There is a small 3/8 hole in the top of the frame member but there is NO rust on the bottom side of the car (jack point/suspension mount). Dman, If you can weld or have a friend who can this is no big deal. Looks like you've got the engine out, so you're well on your way. I'll contradict Andy just a little and say grind out the bad stuff. It's the only way to know for sure how far the damage goes. You may find that 3/8" hole will open up to 6"x4" before you get to solid metal. Trim your holes up nice with an angle grinder or whatever you've got, THEN treat it with medal-ready, then clean it, then spray the area with zinc-chromate weld-through primer and weld your patches on. Then POR-15 it if you want. Be sure you metal-ready, clean, and zinc-prime the underside of the patch area and inside the suspension console/hollow frame area as best you can before you close up the hole. It'll be good for another 30 years. Also check the firewall near your patch area shown - it may be thinner than you think down there at the corner. Good luck - your car doesn't look in bad shape from the pictures. Definitely worth fixing, and you can do this repair in just a couple of hours, easy. -Ben M. |
Pompano Beach 914V8 |
Newbie ![]() Group: Members Posts: 37 Joined: 31-January 03 From: Pompano Beach, Florida Member No.: 216 ![]() |
Seems like no big deal, simple repair. I live on the east coast,...........if no welder........and no grinder........you can't have a 914 <_<
SirAndy |
airsix is right. if you look at my second picture you can see that i cut out the upper hole until i reached solid metal. (did that with the big one too) ...
Jeroen |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,887 Joined: 24-December 02 From: The Netherlands Member No.: 3 Region Association: Europe ![]() |
Wanna trade?
Didn't think so... so quit your whinin' will ya... (IMG:style_emoticons/default/biggrin.gif) get out your grinder and your welder and be done with it make sure you cut out all of the cancer before you stich her back up again cheers, Jeroen (IMG:http://www.berloth.nl/914/pics/r_long03.jpg) |
Dman |
This is the only real rust on the car so I want to fix it and learn to weld. I was planning on replacing the area where the bat tray mounted and it sounds like I can spot fix the other areas.
I have done some pretty wire wheel work and most of the metal in the frame area is in good shape. Thanks guys I am feeling better already I didn't want to do any major panel replacement (IMG:style_emoticons/default/beerchug.gif) |
airsix |
QUOTE(Dman @ Apr 2 2003, 11:46 AM) This is the only real rust on the car so I want to fix it and learn to weld. I was planning on replacing the area where the bat tray mounted and it sounds like I can spot fix the other areas. I have done some pretty wire wheel work and most of the metal in the frame area is in good shape. Thanks guys I am feeling better already I didn't want to do any major panel replacement (IMG:style_emoticons/default/beerchug.gif) I'm sure you were planning on this but just thought I'd mention...If you want to learn to weld do a couple of off-car practice projects or work on some scrap first. That repair would be a tough first-attempt. Welding into that corner is a PITA because you won't be able to see around the gun well. I did that very same repair about 2 years ago as my 3rd welding project and it turned out alright, but if it had been my first project I would have made a big mess. By "a couple of practice projects" I don't mean you need 300 hours behind the gun - Just an hour or two of practice and you should be ready to go. Be sure to practice on steel the same guage as your repair (14 guage?) so you have your technique, speed, and heat worked out before you dive in. It'll turn out great. (IMG:style_emoticons/default/smile.gif) -Ben M. |
Lawrence |
Senior Member ![]() ![]() ![]() Group: Benefactors Posts: 1,661 Joined: 5-February 03 Member No.: 244 Region Association: None ![]() ![]() |
Anything is repairable. (IMG:style_emoticons/default/smile.gif)
seanery |
waiting to rebuild whitey! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 15,857 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None ![]() |
Man, Why is everyones car rusted in the same place? (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/wink.gif)
Lawrence |
Is that a serious question?
Because the battery is poorly placed, and tended to leak acid, as rainwater washed down over the area. The body was never given any rustproofing (such as e-coat) from the factory. Over time, and because of battery design in the 70s and 80s (pre-Optima type battery), it became a huge problem for our babies. I've seen far worse. -Rusty |
SirAndy |
QUOTE(Lawrence @ Apr 2 2003, 04:46 PM) Is that a serious question? nope, seanery is just trying to be me and DD, postwise that is (IMG:style_emoticons/default/wink.gif) |
seanery |
I can't believe I got passed by 2 people!
Damn, I gotta post more. Lawrence, no, it was not a serious question, but I'm sure there is a newbie somewhere who may not know. |
Lawrence |
I only try to post when I'm convinced I'm incredibly witty... or have something constructive to say.
-Rusty (IMG:style_emoticons/default/ar15.gif) 914/6 |
seanery |
Not me, I'd only have 25 posts.
Dave Cawdrey |
Dumbo going poop, Daddy :) ![]() ![]() ![]() Group: Members Posts: 818 Joined: 22-January 03 From: Seattle, WA USA Member No.: 182 ![]() |
This topic, and these pics are making me feel great (IMG:style_emoticons/default/happy11.gif)
Mine aint bad, aint too bad at all (IMG:style_emoticons/default/aktion035.gif) DMAN, yours looks great :finger2: (IMG:style_emoticons/default/wink.gif) |
Bleyseng |
Aircooled Baby! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,036 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest ![]() |
This one was a goner too. Rusted right though the frame rail. When I got it the battery just sat down there spilling acid onto the the rail. It was all rusty and paper thin.
Geoff (IMG:style_emoticons/default/barf.gif) |
Bleyseng |
try this again....
Lo-Fi Version | Time is now: 11th July 2025 - 11:45 AM |
