wtb distributor for carbed motor |
rymann |
Aug 7 2009, 07:07 PM
Newbie Group: Members Posts: 13 Joined: 22-March 09 From: so cal Member No.: 10,191 Region Association: None |
i need a dist. for a 40mm set up...any help is appreciated
thanks (IMG:style_emoticons/default/beerchug.gif) |
tat2dphreak |
Aug 7 2009, 09:22 PM
stoya, stoya, stoya Group: Benefactors Posts: 8,797 Joined: 6-June 03 From: Wylie, TX Member No.: 792 Region Association: Southwest Region |
need more info... what size engine? which cam? does your carbs have vac. advance ports? if not, are you going to drill them?
the mallory is seen as the best... adjustable, too... but about $300 djet distributors are good, and are probably what you want, you can either plug the vacuum ports, or tap your carbs for vac. advance (recommended) if you want a little more advance, the early '74 205AA distributor has 32degrees, vs 27-29 on the djet. 009 is not recommended, but if you want one, I probably have a spare... but seriously, get something else. they suck. |
rymann |
Aug 7 2009, 11:28 PM
hey wayne do u have a 205aa? and how much?? get back to me thanks for the info most helpful
rob |
Lo-Fi Version | Time is now: 13th June 2024 - 02:20 AM |
