rear trunk torsion springs suck |
mightyohm |
Mar 8 2004, 11:57 AM
Advanced Member Group: Benefactors Posts: 2,277 Joined: 16-January 03 From: Seattle, WA Member No.: 162 Region Association: Pacific Northwest |
I spent 3 hours this weekend trying to get the torsion springs for the rear trunk back onto the hinges. They are all the way in the "neutral" position since I had to release tension and replace a hinge pivot some time back. How the heck do you get them back on?
Since I am pretty much giving up anyway, what is the preferred trunk shock kit to use these days and where can I get it? |
Dave_Darling |
Mar 8 2004, 12:45 PM
You put the torsion bars back in position by using a deep-well ~10mm socket plus a longish extension. Or fake up a lever with a notch in the side somewhere near the end.
I'm not sure whose kit is preferred these days, but Camp Counsellor Craig does supply them, and he's a regular around here. Evill Ed did supply them at one point; not sure if he still does or not. Pelican used to carry them, but the last time I looked we had stopped for some reason. We might have picked them back up again in this latest catalog revision... --DD |
mightyohm |
Mar 8 2004, 12:56 PM
Dave, have you ever tried using the socket with the springs ALL the way back against the rear trunk? It doesn't work. You can't bring the bar all the way up and around the hinge post because the engine grille (the side pieces) is in the way
JWest |
Mar 8 2004, 01:25 PM
Senior Member Group: Members Posts: 1,662 Joined: 6-January 03 From: Fort Worth, TX Member No.: 97 Region Association: None |
Jeffs9146 |
Mar 8 2004, 03:54 PM
Ski Bum Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 |
Brad gave me this tip about a year ago!! Best damn tool I ever made!! (IMG:style_emoticons/default/smash.gif)
Jeff Attached image(s) |
mightyohm |
Mar 8 2004, 04:00 PM
looks cool, how do you use it?
Jeffs9146 |
Mar 8 2004, 04:35 PM
Hook it on and push!!
It is very easy! Cut the end of the wrench and you can slide it over the bar, push it back into place and remove it! Jeff |
ruddyboys |
Mar 8 2004, 04:41 PM
Hummel eigentümer Group: Members Posts: 594 Joined: 3-March 04 From: Monroe, NY Member No.: 1,749 Region Association: North East States |
My car never had the bars hooked up. They show how to hook up the one end in the haynes manual around the roller, but how does the other end connect? Is there a picture of the whole assembly hooked up.
mightyohm |
Mar 8 2004, 04:44 PM
QUOTE(Jeffs9146 @ Mar 8 2004, 02:35 PM) Hook it on and push!! It is very easy! Cut the end of the wrench and you can slide it over the bar, push it back into place and remove it! Jeff Push over 6 inches with 150 pounds of force you mean!! I will try that. I was trying to use a jack handle this weekend with a notch cut out but the bar kept slipping just as I got it up against the post on the hinge. The other problem is the jack handle was too large of a diameter and I would run into stuff as I tried to push the spring the last couple inches. |
Gint |
Mar 8 2004, 06:01 PM
Mike Ginter Group: Admin Posts: 16,083 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
Jeffs9146 |
Mar 8 2004, 06:22 PM
The key is the proper leverage on the proper tool!! Trust me, it is easy with this tool! You have to line the wrench up just past the bend in the bar and push. I was surprised at how easy it went on compared to the 3 hours I spent trying to do it without the proper configuration!!! One side at a time and be patient it will fall into place!
Jeff |
Kargeek |
Mar 8 2004, 06:33 PM
Senior Member Group: Members Posts: 555 Joined: 14-March 03 From: Orange, CA Member No.: 430 |
The trunk shocks are a good way to go if you are not hung up on originality. It allows additional room in the engine compartment too. The Camp 914 kit I hear is good. I made my own using Porsche 944 rear hatch shocks. You can see pics in the attached link.
Dave's 914 |
Bruce Allert |
Mar 8 2004, 06:39 PM
Hellions asleep Group: Members Posts: 3,289 Joined: 19-March 03 From: Eagle Creek, Orygun Member No.: 441 Region Association: Pacific Northwest |
I can vouch for Craigs kit. Got it on mine and they are easy install too. I used 2 small pipe wrenches for the springs. Took them off really easy. Put them back on just for grins then took 'm off again (IMG:style_emoticons/default/blink.gif) Pipe wrench size was 8" long.
.....b |
lmcchesney |
Mar 8 2004, 06:48 PM
Member Group: Members Posts: 488 Joined: 24-November 03 From: Ocala, Fl. Member No.: 1,381 Region Association: None |
Had the same problem. Mine were off for 6 years.
The deep socket is used to replace the rollers, which require the up right portion of the spring rod to be behind the axle for the roller. I too tried to explain this to Dave without success. The socket is restricted from complete travel. I've looked for the "Ricky-Do" tool without success. The notched jack lever is good to scrape your knuckles and learn to curse. I was finally able to achieve success using Two Vice Grips. With the holding brackets loosely in place, grasp the spring rod on each side of the bracket. Then roll the rod back toward the roller axle using the vice grip. Alternate the bites on the vice grips to continue to retract the up right portion of the spring rod until the socket can be placed over the up right end. Once the up right is behind the roller axle, tighten the brackets and replace the roller. No unique tools and decreased danger to yourself. L. McChesney |
Jeffs9146 |
Mar 8 2004, 08:50 PM
QUOTE I was finally able to achieve success using Two Vice Grips. With the holding brackets loosely in place, grasp the spring rod on each side of the bracket. Then roll the rod back toward the roller axle using the vice grip. Alternate the bites on the vice grips to continue to retract the up right portion of the spring rod until the socket can be placed over the up right end. Once the up right is behind the roller axle, :wacko: tighten the brackets and replace the roller. No unique tools and decreased danger to yourself. Trust me, the modified wrench is the way to go!! Jeff |
maf914 |
Mar 9 2004, 08:16 AM
Not a Guru! Group: Members Posts: 3,049 Joined: 30-April 03 From: Central Florida Member No.: 632 Region Association: None |
Jeff,
Good idea. Is that a 10" or 12" adjustable wrench? Is there any reason a modified box end wrench would not work? I may have a few extras around that could be cut. I wonder what the chances are of the cut ring fracturing under load? I don't think even Sears would exchange a Craftsman tool with this alteration! (IMG:style_emoticons/default/laugh.gif) Mike |
Jeffs9146 |
Mar 9 2004, 10:34 AM
QUOTE Is that a 10" or 12" adjustable wrench It is a 12" wrench. I used an old wrench and was worried about the ring breaking but it held up fine! I think the metal on the adjustable wrench is thicker than on a box end wrench. Also the straite handle is better than the bent one. Jeff |
mightyohm |
Mar 9 2004, 10:29 PM
Jeff, I made the tool. I still can't figure out how to use it. Here's where I am now. What do I do next?
I don't have enough leverage to just push the bar without the wrench slipping down. Attached image(s) |
campbellcj |
Mar 9 2004, 10:46 PM
I can't Re Member Group: Members Posts: 4,550 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California |
Andyrew |
Mar 9 2004, 11:19 PM
Spooling.... Please wait Group: Members Posts: 13,376 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California |
I cut mine off, I use a tripod stick to hold my hood up.. Ah heck, I guess I can buy some shocks for 40 bucks.
Andrew |
Lo-Fi Version | Time is now: 17th June 2024 - 12:00 AM |
