Is there a quick way to check the rear wheel bearings? |
SirAndy |
Aug 11 2009, 11:41 AM
Resident German Group: Admin Posts: 41,681 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Dr. Roger |
Aug 11 2009, 11:59 AM
A bat out of hell. Group: Members Posts: 3,944 Joined: 31-January 05 From: Hercules, California Member No.: 3,533 Region Association: Northern California |
don't you just jack up the rear and grab hold of the rear wheels and give them a jiggle? too much juggle means too much wear. it's what the PCA uses during tech inspection. |
Joe Bob |
Aug 11 2009, 12:04 PM
Do da jiggle....
puff adder |
Aug 11 2009, 12:18 PM
Member Group: Members Posts: 77 Joined: 9-December 08 From: northern california Member No.: 9,827 Region Association: None |
What about regreasing the rear wheel bearings?
On the list of things to do is check and lube EVERYTHING on my race car. |
underthetire |
Aug 11 2009, 12:29 PM
914 Guru Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California |
IronHillRestorations |
Aug 11 2009, 03:37 PM
I. I. R. C. Group: Members Posts: 6,731 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
Jack up the car, do the jiggle as above. You can also pry up on the wheel and see if there's slack.
URY914 |
Aug 11 2009, 03:49 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 121,070 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
Simple test....
No noise = good Noise = bad |
turnaround89 |
Aug 11 2009, 04:27 PM
Senior Member Group: Members Posts: 671 Joined: 17-May 08 From: Rockford, Illinois Member No.: 9,067 Region Association: Upper MidWest |
wouldn't the bearing cover stop the jiggle?
SLITS |
Aug 11 2009, 05:28 PM
charliew |
Aug 11 2009, 05:32 PM
Advanced Member Group: Members Posts: 2,363 Joined: 31-July 07 From: Crawford, TX. Member No.: 7,958 |
I wasn't aware the 914 had rear wheel bearings.
Eric_Shea |
Aug 11 2009, 05:55 PM
PMB Performance Group: Admin Posts: 19,278 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
The "quick" way when I was tech'ing for PCA was to place both hands on or near the top of the tire and rock the car back and forth. Listen for a click or clunk. You can always find a bad or loose bearing front or rear that way. No need to jack anything.
r_towle |
Aug 11 2009, 06:01 PM
Custom Member Group: Members Posts: 24,591 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
remove the bearing....it will be bad then.
Rich |
davep |
Aug 11 2009, 06:02 PM
914 Historian Group: Benefactors Posts: 5,154 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
charliew |
Aug 11 2009, 06:07 PM
The 914 has a double row rear HUB/AXLE bearing. The only wheel bearings I know of are on the front of rear drive cars.
URY914 |
Aug 11 2009, 06:37 PM
Bad bearing race: Attached thumbnail(s) |
type2man |
Aug 11 2009, 07:17 PM
Member Group: Members Posts: 353 Joined: 3-March 09 From: Miami, Fl Member No.: 10,127 Region Association: South East States |
A good way to test the bearings is to speed up to about 50 mph and shut the engine off and coast(DONT TURN THE KEY TO WHERE IT LOCKS THE COLUMN!!!). Rock the steering wheel from side to side slowly. Bad bearings will give you a roar or a hum when a side load is a applied.
SirAndy |
Aug 12 2009, 12:27 AM
The "quick" way when I was tech'ing for PCA was to place both hands on or near the top of the tire and rock the car back and forth. Listen for a click or clunk. You can always find a bad or loose bearing front or rear that way. No need to jack anything. Wouldn't the rear one piece bearing have to be completely shot to give you a "clunk"? For the front, the jiggle makes sense as there's not much support for the two piece bearing. In the rear, with everything assembled, one would think that a worn bearing would still sit pretty tight on the large surface. Also, there's so much noise from the calipers and axles when turning the wheel by hand, you can't really tell unless your bearing was already in a million pieces. Am i just doing this wrong? I'm getting some weird grinding noises from the rear when driving, but neither the jiggle nor listening while turning the wheel by hand produce any obvious results. (IMG:style_emoticons/default/confused24.gif) Andy |
charliew |
Aug 13 2009, 12:12 AM
Have you tried putting it in neutral and coasting to see if it's in the tranny? Or as Typ2 man suggested turning in circles in neutral to see if it changes the sound?
SirAndy |
Aug 13 2009, 11:41 AM
Have you tried putting it in neutral and coasting to see if it's in the tranny? Or as Typ2 man suggested turning in circles in neutral to see if it changes the sound? Yes. You can clearly hear a grinding noise from the rear. Metal to metal. Depending on how you load/unload the suspension. Even at very low speeds (think getting into the driveway at an angle) ... I thought it might be my brake rotors hitting the calipers, but turning down the rotors didn't make a difference. And there are no wear marks on the calipers. The sound goes with the revolution of the wheels, not the motor ... (clutch in/out makes no difference) ... What else could it be besides the wheel bearings? (IMG:style_emoticons/default/confused24.gif) Andy |
jcd914 |
Aug 13 2009, 01:08 PM
Advanced Member Group: Members Posts: 2,081 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
Do you have a limited slip diff? Porsche LSD without the proper gear oil or additive can be noisy. When you turn to load the suspension one side or the other you also force the diff to work. That said, your description does sound like wheel bearings to me and I suspect you put some hefty side loads on the rear suspension. If you can put it up on a rack and run it in gear and listen with a stethoscope you will probably find 1 side louder that the other. This takes at least 2 people, 1 in the driver seat a 2nd to listen, if you have a 3rd to watch for safety hazards, could save you from lifting you head into a hot header or such. Of course up on a lift changes the load on the bearings and they maybe quiet the. You will also get a lot of other noise and vibration so it can be a challenge to sort out. Spin up the wheels and then put in neutral and shut off the engine and listen as the wheels coast down. I know this does not count as an easy method and it does not even work all the time but it is something you can do short of replacing both rear bearings. Good Luck Jim |
Lo-Fi Version | Time is now: 11th June 2024 - 03:42 AM |
