dual carb linkage |
dual carb linkage |
karmanbuilt |
Aug 17 2009, 12:15 PM
??? Group: Members Posts: 72 Joined: 7-July 08 From: Emmett, ID. Member No.: 9,262 Region Association: Pacific Northwest |
Recently bought a pair of Dual 40s from Jake at his site. Set up the carbs, manifolds, and linkage per installation instructions. Problem is the passenger side linkage coming off the end of the cross bar is hitting the bars(SPRING) of the deck lid, not allowing full throttle action. Tried different positioning, but same affect. Thought about hitting the spring w/hammer, but that's not good! Also removing spring bars all together. Enclosing attachment of sample car with same set up......not mine. Thoughts.......??
jmill |
Aug 17 2009, 12:38 PM
Green Hornet Group: Members Posts: 2,449 Joined: 9-May 08 From: Racine, Wisconsin Member No.: 9,038 Region Association: Upper MidWest |
Change the linkage around to the front.
You can call up Jake for advice or post on his forum too. He's real good at supporting his customers. You'll need to get an actual picture of your setup to show him though. Someone elses pic without the same issue doesn't help much. |
neil30076 |
Aug 17 2009, 12:40 PM
Recovering dismantler! Group: Members Posts: 397 Joined: 12-September 06 From: San Diego ( RB) CA Member No.: 6,826 Region Association: Southwest Region |
(IMG:style_emoticons/default/agree.gif) Check out this thread, many pictures onhow to set them correctly http://www.914world.com/bbs2/index.php?showtopic=98073 |
Lo-Fi Version | Time is now: 10th June 2024 - 10:39 AM |
