| SirAndy |
Aug 18 2009, 12:45 AM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,473 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
My '95 993 Motor is a pre-varioram OBD1 Motor and i have been toying with the idea of updating it to OBD2.
There was, for a short time, a OBD2 brain available for the (still aircooled) 993 starting in '96 with the varioram version of the motor. It is my understanding that besides the tubes inside the intake, the two motors are pretty much identical. I wonder if i could get a later brain and harness and make it work with my engine. Is there anyone out there who has tried this? (IMG:style_emoticons/default/idea.gif) Andy |
| SirAndy |
Aug 18 2009, 03:36 PM
Maybe i need to post this on 993world.com ... (IMG:style_emoticons/default/biggrin.gif)
| r_towle |
Aug 18 2009, 03:40 PM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
I dont see why not.
You would need to verify the values of the sensors from both motors....might need to change a few sensors to get them into the right ranges... Aside from that, its all just reading electronics....should be fairly do able. It would probably help ALOT if you could get into a shop that had an OBD car hooked up to a computer so you could get some of the basic readings...and see what they look like. Worst case, you need a scope to check your motor/sensors. Rich |
| Cupomeat |
Aug 18 2009, 03:56 PM
missing my NY 914 in VA ![]() ![]() ![]() Group: Members Posts: 1,349 Joined: 26-November 07 From: Oakton VA Member No.: 8,376 Region Association: MidAtlantic Region |
The basic hard parts of the 95 and 96-98 993 3.6l motors are mostly identical so there should be no issues there.
Are you planning on using the vario-ram intake on the 95 993 long block? If not, why do the coversion? Also, the ODBII exhaust has additional O2 sensors that the 95 exhaust doesn't have. You'll need to either source a later exhaust or weld in bungs. Honestly, what will you gain with the ODBII upgrade besides the 10 hp from the Vario-Ram? I am very interested as I have a 95 993 and chose it to avoid some of the problems associated with the ODBII cars. Very interesting idea, BTW. |
| ghuff |
Aug 18 2009, 04:13 PM
This is certainly not what I expected down here. ![]() ![]() ![]() Group: Members Posts: 849 Joined: 21-May 09 From: Bodymore Murderland Member No.: 10,389 Region Association: MidAtlantic Region |
Why go OBDII, why not go stand alone?
What is better about OBDII vs standalone besides easy plug in diagnosis? Knowing euro supplies/manu's I am willing to bet you would need some sort of porsche software to get the real data out of that ECU. |
| SirAndy |
Aug 18 2009, 07:14 PM
Why do the coversion? I have access to an OBD2 wireless data logger chip that uses satellites to communicate in real time to a central server that lets you stream the data into a customized Google maps webpage. Real time position tracking, acceleration, braking, g-forces as well as any engine related data available from the brain. Rpm, ignition advance, pressures, temps, error codes etc. And because it uses satellites there's no need to be within cell phone tower range. Works pretty much anywhere. And best of all, it's all free of charge! (IMG:style_emoticons/default/w00t.gif) Andy |
| McMark |
Aug 18 2009, 07:22 PM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,180 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None |
Cool! (IMG:style_emoticons/default/thumb3d.gif)
| Chris Hamilton |
Aug 18 2009, 07:24 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 611 Joined: 7-March 06 From: Berkeley, CA Member No.: 5,687 |
I'd go with an aftermarket ECU that does OBD II (IMG:style_emoticons/default/biggrin.gif)
| Cap'n Krusty |
Aug 18 2009, 07:39 PM
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California |
From what OBD2 stuff I deal with, I have a couple of thoughts. If the system you're controlling is missing components, you may have insurmountable issues. If you're expecting full OBD2 performance out of a 1996 unit, you're NOT gonna get it. It was only slightly more sophisticated than the OBD1 unit it replaced, and lacks a LOT of functions. If you were to change the entire induction/exhaust system to go with the ECU, and you had all the other monitoring components in your car, you might have SOME of the functions you seek, but they might also be pretty basic. Later OBD2, which is pretty well developed after 12-13 years, has hundreds, probably even thousands, of functions, and would be ideal for your use. Remember, however, that there's no such thing as a free puppy, and this puppy could end up costing you a TON.
The Cap'n |
| SirAndy |
Aug 18 2009, 08:53 PM
From what OBD2 stuff I deal with, I have a couple of thoughts. If the system you're controlling is missing components, you may have insurmountable issues. If you're expecting full OBD2 performance out of a 1996 unit, you're NOT gonna get it. It was only slightly more sophisticated than the OBD1 unit it replaced, and lacks a LOT of functions. If you were to change the entire induction/exhaust system to go with the ECU, and you had all the other monitoring components in your car, you might have SOME of the functions you seek, but they might also be pretty basic. Later OBD2, which is pretty well developed after 12-13 years, has hundreds, probably even thousands, of functions, and would be ideal for your use. Remember, however, that there's no such thing as a free puppy, and this puppy could end up costing you a TON. True enough. I know i won't get the same functionality as from a contemporary OBD2 car. I'll be happy if i get the basics from the engine and hopefully never have to look at any error codes. The main reason would be so i can run the wireless setup to track the car remotely. Any additional data collected is just a added bonus. The Accel/Decel/Gps/Speed/Gs is all done inside the Chip, so that info will always be available. (IMG:style_emoticons/default/popcorn[1].gif) Andy |
| ghuff |
Aug 18 2009, 08:56 PM
From what OBD2 stuff I deal with, I have a couple of thoughts. If the system you're controlling is missing components, you may have insurmountable issues. If you're expecting full OBD2 performance out of a 1996 unit, you're NOT gonna get it. It was only slightly more sophisticated than the OBD1 unit it replaced, and lacks a LOT of functions. If you were to change the entire induction/exhaust system to go with the ECU, and you had all the other monitoring components in your car, you might have SOME of the functions you seek, but they might also be pretty basic. Later OBD2, which is pretty well developed after 12-13 years, has hundreds, probably even thousands, of functions, and would be ideal for your use. Remember, however, that there's no such thing as a free puppy, and this puppy could end up costing you a TON. The Cap'n Yes. Most OBDII units that allow you to monitor what is going on do not support anything that the OP mentioned. you might be able to see O2, coolant temp, throttle position, generic OBDII stuff. Like one of the scan tools that you can plug in and monitor your mileage etc. I had explored the most that a Snap-ON Modis unit would do with plain jane OBDII and was left very unimpressed. What you are looking for, you need standalone. Forget error codes, take control of the car and know what it is all doing 100% of the time. |
| SirAndy |
Aug 18 2009, 09:00 PM
What you are looking for, you need standalone. Forget error codes, take control of the car and know what it is all doing 100% of the time. (IMG:style_emoticons/default/confused24.gif) Are we reading the same posts? (IMG:style_emoticons/default/huh.gif) Andy |
| ghuff |
Aug 18 2009, 09:16 PM
What you are looking for, you need standalone. Forget error codes, take control of the car and know what it is all doing 100% of the time. (IMG:style_emoticons/default/confused24.gif) Are we reading the same posts? (IMG:style_emoticons/default/huh.gif) Andy Yes. Again you want to know what is going on 100% you will need standalone. OBDII generic data is just not enough. You may or may not get what you want, it really depends on how Porsche adhered to OBD2. http://www.greddy.com/featured/104touch060909.pdf Look at the supported functions, and breakdown of that device. The most you will get is really dependant on the Porsche OBDII and how it adheres to the standard. There are a plethora of these devices available that all do the same thing. If you want to test it, find a shop with a Snap-ON modis and go into standard OBD2 mode and see exactly what you can see on an OBD2 car of someone you know. The modis is one of the best. The standard OBD2 values I could monitor on my CANBUS 2001 GTi with drive by wire was sorely lacking. Coolant temp, o2 value (worthless unless you have a factory wideband) etc. I imagine a 1996 OBDII being much worse or equal. 100% not worth the effort. Now the internal functions and KWP(K wire protocol requiring a VAG-COM or a vag 50,000$ tool) accesible values I could monitor were worthwhile. Per cylinder knock, per cylinder trims for timing. etc. OBD2 is not just OBD2..... QUOTE(wikipedia) OBD-II Diagnostic connector Connector The OBD-II specification provides for a standardized hardware interface—the female 16-pin (2x8) J1962 connector. Unlike the OBD-I connector, which was sometimes found under the hood of the vehicle, the OBD-II connector is nearly always located on the driver's side of the passenger compartment near the center console. SAE J1962 defines the pinout of the connector as: 1. - 2. Bus positive Line of SAE-J1850 PWM and SAE-1850 VPW 3. Ford DCL(+) Argentina, Brazil (pre OBD-II) 1997-2000, Usa, Europe, etc. 4. Chassis ground 5. Signal ground 6. CAN high (ISO 15765-4 and SAE-J2284) 7. K line of ISO 9141-2 and ISO 14230-4 8. - 9. - 10. Bus negative Line of SAE-J1850 PWM only (not SAE-1850 VPW) 11. Ford DCL(-) Argentina, Brazil (pre OBD-II) 1997-2000, Usa, Europe, etc. 12. - 13. - 14. CAN low (ISO 15765-4 and SAE-J2284) 15. L line of ISO 9141-2 and ISO 14230-4 16. Battery voltage The assignment of unspecified pins is left to the vehicle manufacturer's discretion. [edit] Signal protocols There are five signalling protocols currently in use with the OBD-II interface. Any given vehicle will likely only implement one of the protocols. Often it is possible to make an educated guess about the protocol in use based on which pins are present on the J1962 connector: * SAE J1850 PWM (pulse-width modulation - 41.6 kbaud, standard of the Ford Motor Company) o pin 2: Bus+ o pin 10: Bus– o High voltage is +5 V o Message length is restricted to 12 bytes, including CRC o Employs a multi-master arbitration scheme called 'Carrier Sense Multiple Access with Non-Destructive Arbitration' (CSMA/NDA) * SAE J1850 VPW (variable pulse width - 10.4/41.6 kbaud, standard of General Motors) o pin 2: Bus+ o Bus idles low o High voltage is +7 V o Decision point is +3.5 V o Message length is restricted to 12 bytes, including CRC o Employs CSMA/NDA * ISO 9141-2. This protocol has a data rate of 10.4 kbaud, and is similar to RS-232. ISO 9141-2 is primarily used in Chrysler, European, and Asian vehicles. o pin 7: K-line o pin 15: L-line (optional) o UART signaling (though not RS-232 voltage levels) o K-line idles high o High voltage is Vbatt o Message length is restricted to 12 bytes, including CRC * ISO 14230 KWP2000 (Keyword Protocol 2000) o pin 7: K-line o pin 15: L-line (optional) o Physical layer identical to ISO 9141-2 o Data rate 1.2 to 10.4 kbaud o Message may contain up to 255 bytes in the data field * ISO 15765 CAN (250 kbit/s or 500 kbit/s). The CAN protocol is a popular standard outside of the US automotive industry and is making significant in-roads into the OBD-II market share. By 2008, all vehicles sold in the US will be required to implement CAN, thus eliminating the ambiguity of the existing five signalling protocols. o pin 6: CAN High o pin 14: CAN Low Note that pins 4 (battery ground) and 16 (battery positive) are present in all configurations. Also, ISO 9141 and ISO 14230 use the same pinout, thus the connector shape does not distinguish between the two. Perhaps I can clarify it more for you if need be? (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/shades.gif) |
| r_towle |
Aug 18 2009, 11:03 PM
Andy,
the system will be monitoring fuel, emmissions, throttle position, air flow (inbound), head temps, ambient air temp, and probably a few more I cant think of. It will need two 02 sensors, on on each side of the cat. They are different, so research that. the front one gives a variable signal, the rear one has a target of a constant signal. Its in a range of 0-1 volts... Its pretty well documented. Each ECU is different and each car uses simple basic sensors that send 0-1 volts in a specific window...like 300 milli volts to 350 millivolts if the car is at the perfect operating temp. As long as you have all the right sensors, it should work. You can fool the ECU with resistors to get the reading in the right range. Rich |
| SirAndy |
Aug 19 2009, 01:19 AM
Perhaps I can clarify it more for you if need be? Well, you did just clarify that you didn't get what i want at all. Which is why i asked if you had actually read my posts. So, thanks for clearing that up. Like i stated above, i already have the data logger. It connects to OBD2. It can read Porsche specific data. But the real interest lies in the fact that it can transmit data wireless in realtime and has build in GPS and can measure G-Force, acceleration and braking. The actual data coming from the engine is just a added bonus. So no, i don't "want to know what is going on 100%" ... (IMG:style_emoticons/default/driving.gif) Andy PS: Nice copy & paste. Is that from Wikipedia? |
| SirAndy |
Aug 19 2009, 01:23 AM
Andy, the system will be monitoring fuel, emmissions, throttle position, air flow (inbound), head temps, ambient air temp, and probably a few more I cant think of. It will need two 02 sensors, on on each side of the cat. They are different, so research that. the front one gives a variable signal, the rear one has a target of a constant signal. Its in a range of 0-1 volts... Its pretty well documented. Each ECU is different and each car uses simple basic sensors that send 0-1 volts in a specific window...like 300 milli volts to 350 millivolts if the car is at the perfect operating temp. As long as you have all the right sensors, it should work. You can fool the ECU with resistors to get the reading in the right range. Yes, i believe there was also a secondary air injection system on the later models. I might have to fool some of the sensors. No Cat, just headers. Adding a second O2 sensor is easy, but i have to look into the different signals. I'd probably just switch to the later upper intake to get the tubes inside the plenum. What about the dashboard interlock system? Was that part of the main brain? If so, can it be disabled? (IMG:style_emoticons/default/idea.gif) Andy |
| ClayPerrine |
Aug 19 2009, 07:24 AM
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,542 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille
Andy....
You do realize that a varioram intake won't fit under a 914 engine lid. (IMG:style_emoticons/default/biggrin.gif) That being said, the dashboard interlock is incorporated into the ECU, as is the Tiptronic transmission controls, if so equipped. The dashboard interlock can be bypassed, but it is an expensive chip you have to buy. It can be done, but it will take some downtime for your car. If I were doing it, I would get the whole varioram induction system for the ODB 2 car with the harness, not just the ECU. Then spend some time with the wiring diagrams and documentation and determine what you can and can't disconnect. The data logging and tracking of the car sounds really cool! I would love to have something like that in my car. Unfortunately MFI doesn't lend itself to data logging....... LOL. |
| SirAndy |
Aug 19 2009, 11:31 AM
Maybe it would be easier to figure out how to convert the engine output from OBD1 to OBD2 and feed that into the data logger ... (IMG:style_emoticons/default/type.gif)
| Chris Hamilton |
Aug 19 2009, 12:36 PM
Maybe it would be easier to figure out how to convert the engine output from OBD1 to OBD2 and feed that into the data logger ... (IMG:style_emoticons/default/type.gif) (IMG:style_emoticons/default/idea.gif) Andy That's why I suggest an aftermarket ECU. That would probably be a bunch more configurable for outputs. I remember hearing something about the haltechs that do CANBUS being able to output OBDII signals. You might even pick up a couple extra horsepressures while you're at it. |
| ghuff |
Aug 20 2009, 12:49 AM
Perhaps I can clarify it more for you if need be? Well, you did just clarify that you didn't get what i want at all. Which is why i asked if you had actually read my posts. So, thanks for clearing that up. Like i stated above, i already have the data logger. It connects to OBD2. It can read Porsche specific data. But the real interest lies in the fact that it can transmit data wireless in realtime and has build in GPS and can measure G-Force, acceleration and braking. The actual data coming from the engine is just a added bonus. So no, i don't "want to know what is going on 100%" ... (IMG:style_emoticons/default/driving.gif) Andy PS: Nice copy & paste. Is that from Wikipedia? Well Andy, it sounds like you certainly know it all and have this 100% under control since you knew ahead of time that your module is fine with the Porsche OBD2 you were considering swapping over to. Seems like this entire thread was not needed! Yes, that is from wikipedia. Great reference when you know what you are looking for is it not? (IMG:style_emoticons/default/shades.gif) |
Lo-Fi Version | Time is now: 16th April 2026 - 10:24 PM |
