Advice needed for this Rust Repair, Passenger Front Fender |
bobhasissues |
Aug 19 2009, 07:54 PM
seemingly endless issues with my 914 Group: Members Posts: 218 Joined: 13-February 07 From: Chicagoland Member No.: 7,532 Region Association: None |
Has anyone dealt with this situation without replacing the entire fender?
The double paneled section rusted from the inside out, but the rust is isolated to the cowl area. The rest of the fender is rust and dent free in and out. |
dr914@autoatlanta.com |
Aug 19 2009, 09:10 PM
914 Guru Group: Members Posts: 7,869 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
you will have to cut out the top and fabricate a patch panel and weld it in restoring the cowl seal area. Our men do it all the time if you want to call for a step by step
r_towle |
Aug 19 2009, 09:25 PM
Custom Member Group: Members Posts: 24,579 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
You are making a very good start by leaving the edge of the fender alone if you can.
The tricky part of this is getting a spoon in underneath to hammer the weld down flat.. Plan ahead and you can do it... Its similar on a 356 and I have done a few. Hammering the weld sucks...but you end up welding in the bottom piece last in some cases so you can get it done. OR. Replace the whole fender RIch |
bobhasissues |
Aug 19 2009, 09:39 PM
you will have to cut out the top and fabricate a patch panel and weld it in restoring the cowl seal area. Our men do it all the time if you want to call for a step by step George, Is the vertical portion of the fender (the outside edge of the cowl seal channel) welded to the edge of the cowl where they meet, or is my remaining metal being held in place by a panel adhesive or seam sealer? The vertical section looks well rusted as well and probably isn't weldable. I was afraid to cut away any more until I understand the anatomy of this area. |
bobhasissues |
Aug 19 2009, 10:01 PM
You are making a very good start by leaving the edge of the fender alone if you can. The tricky part of this is getting a spoon in underneath to hammer the weld down flat.. Plan ahead and you can do it... Its similar on a 356 and I have done a few. Hammering the weld sucks...but you end up welding in the bottom piece last in some cases so you can get it done. OR. Replace the whole fender RIch The edge along the door looks good inside and out, and it appears I might be able to leave a little bit of a "lip" on the bottom side skin so I can lay the patch on the lip and it will be flush with the existing edge along the door. Like you said, I was thinking the best approach would be fix the outer skin first with the door in place as a guide. Then remove the door to fix the inner side. I'm struggling with the curvy vertical part that runs parallel to the cowl edge. I did not cut that out yet, but it's flaky and has pinholes. That section would surely blow right through if I tried to weld it (and I'm not sure that section is welded in or just being held by the existing seam sealer. Any ideas? |
bobhasissues |
Aug 21 2009, 10:34 AM
bump,
still seeking additional advise |
FourBlades |
Aug 21 2009, 02:37 PM
From Wreck to Rockin Group: Members Posts: 2,054 Joined: 3-December 07 From: Brevard, FL Member No.: 8,414 Region Association: South East States |
I did this same repair on both sides of my car. I have some pictures in my
1973 restoration thread somewhere around page 8 or 9 or so. On my car, the lower layer of metal was good on one side and non existent on the other. I did not replace the lower section on the side where it was rusted out. My car is not really what you would call concours so I did not worry about it. Make sure you have your door mounted right so you can tell if your fender line will match up. Also, weld it slowly and let it cool frequently or it will warp big time. Jeff Hail's thread has some great pictures of repairing the lower layer of this area. John |
Lo-Fi Version | Time is now: 23rd May 2024 - 01:51 AM |
